jml755
Marginal? Anything but. It is no better or worse then a 2x4 on 8' center. Both 2x4 on 8' and 2x6 on 12' are a "simple solution that is well documented as acceptable pole barn design".
I never implied that his truss couldn't set on a header. Insisting that he can't have a 12' span is even less helpful. Must be one of these I have never seen or done it so it can't be done.
:laughing: No need to get snotty, I'm not "I]I have never seen or done it so it can't be done[/I]" I'm one of those "design to engineered standards" and when I said "marginal", I was citing figures from actual span tables for joists/rafters with the lightest loads listed. Here's a link to one of many: "http://wclib.com/pdfs/SimpSpanTbls.pdf". I don't know of any tables for "purlins" but looking at the rafter and joist spans for 2x6's on 24"o.c. will give anyone an idea at what a particular dimensional piece will support. Note that it varies depending upon grade of lumber AND the anticipated loading. With purlins and rafters, snow loads are probably the biggest consideration since they don't see higher "live" loading like a joist. There are conditions where a 2x6 will span 12' but I see those to be using "select structural" lumber. Here in Michigan most of our stuff is simply SPF so I use those columns.
