Poor Mans Fuel pump
   / Poor Mans Fuel pump
EROSOL,
I do have a 300 gallon gravity tank I have filled every winter with gasoline and my jobber carries diesel on the same truck. This particalur filling I loaded the drum into into the bed of my truck on a pallet (strapped down well) and filled it at my local gas station two miles away. I unloaded it with my FEL and forks. I only put in 25 gallons since I don't use much in the winter.
RALPHVA,
I bought the fluid from a local oil jobber that distributes to local stores. It cost me $61.00 with tax. The plastic drums have the same bung holes as the metal drums and that is exactly how I did it.
LBROWN59,
I do treat the fuel with Power Service. There is no filter on this setup. The tank was very clean (originally contained windshield fluid) so I saw no reason for a filter since the fuel was filtered at the pump and again on the tractor. I have the tank setting off the floor with wood to minimize condensation. I don't see any more condensation occuring here as compared to my original 5 gallon can setup. Good idea for the water separator, I need one for my new paint gun anyway.
SCHMISM,
I store this drum inside the barn where it is usually dark but I will keep my eye on that issue. I have seen that slime when I was an aircraft mechanic from Jet fuel....Nasty looking stuff.
DIRTHOG & DIELSEPOWER,
I agree, I am very careful to let the air flow at a very slow rate. It is amazing how little air it takes to make the fuel flow. I also have my regulator at the compressor set to under 10 lbs just as backup. I wouldn't use this method with gasoline and still have my compressor unplugged while fueling so that it doesn't cycle on.
   / Poor Mans Fuel pump #12
jejeosborne said:
EROSOL,
SCHMISM,
A question for the group.
This slime; is it little critters that eats up the fuel? An interesting thought, when there is a fuel spill, why do we have to clean it up if nature will eat up the stuff anyway? I read a question one time asking, "Where does all the rubber from the tires go when the worn rubber is brushed to the side of the road as cars go by?" If I remember right; the answer was the little particles were eaten by bacteria. By the way, I not suggesting we don't clean up fuel spills. I just wonder why bacteria doesn't eat up the spill. Oil is a "natural" product. Hey, maybe it is good to eat.
Just a thought. Got to stop thinking, that's what always gets me into trouble.
Cheers....Coffeeman
   / Poor Mans Fuel pump #13
Cheers....Coffeeman
I think I read that the slime lives in the boundary layer between the fuel and the water, it requires certain conditions to live and reproduce. If it gets a good environment it can grow pretty quickly. I have seen some major slime colonies in marine environments.
Dave
   / Poor Mans Fuel pump #14
dpdee13 said:
I think I read that the slime lives in the boundary layer between the fuel and the water, it requires certain conditions to live and reproduce. If it gets a good environment it can grow pretty quickly. I have seen some major slime colonies in marine environments.Dave
That is how it works. It lives in the boundry between the fuel and watter and not actually in the fuel.
   / Poor Mans Fuel pump #15
I guess my solution is a bit low tech for y'all. Around here, lots of folks use supplemental kerosene heaters. All the local stores sell squeeze bulb syphons so the 1 gallon heater tanks can be filled from the 6 gallon cans everybody has. I just buy one every year or so, and set my diesel can on the hood of the tractor. There's a hole to access the tank filler cap in the hood. A couple of squeezes and fuel syphons from the can to the tank, I don't have to pour, and can stop it when the tank gets full. Cost me about $7.50 a year, and liftin' a 36 lb can ain't that troublesome if'n you don't have to tip it over to pour.
   / Poor Mans Fuel pump #16
Good idea Slamfire. They also make those type pumps for 55 gallon drums. They screw into the hole and you can pump away. Cheap and easy.
   / Poor Mans Fuel pump #17
Lord I'm workin' hard to burn more'n 5 gallons a month, the stuff'd git stale.
   / Poor Mans Fuel pump #18
Man, I knew the safety police were gonna get you for using air. Just be careful.
   / Poor Mans Fuel pump #19
Just like Diesel Power said. Using air on a barrel is a disaster just awaiting to happen. More than one person has been killed doing this. :mad:
Barrels are not pressure vessels. Any type of failure to limit pressure applied and its a bomb. Just a pressure regulator itself is not acceptable.
   / Poor Mans Fuel pump #20
People have been killed airing up tires (a sort of pressure vessel), fueling vehicles, airing up portable air tanks, welding, etc, etc. I realize maybe not the best option, but he said "poor" mans fuel pump. He is just sharing an idea that he came up with. So what is off limits? I guess maybe the moderators should just delete a post like this, or how crazy of an idea does it have to be before it's deleted? Just curious.
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
CAT Skid Steer Grapple (A51573)
CAT Skid Steer...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
2016 LINK-BELT  235X3 SPIN ACE EXCAVATOR (A52472)
2016 LINK-BELT...
