Power Beyond or HPCO valve help needed
   / Power Beyond or HPCO valve help needed #21
When taking fittings apart, which would you rather clean up before reassembly, paste or tape?
   / Power Beyond or HPCO valve help needed #22
Neither one is difficult to clean up. The people that get in a hurry are the ones who forget.
I just took the Gesen V12 valve apart and built a power beyond adapter to fit it. I posted several photos and a dimensioned drawing in my photo album, Bobs Backhoe on this site. I will put it back together and test it in a few days if the weather holds out. Hopefully this will avoid the problems with too much pressure on the seals of any valve in the system.
The original adapter I built had a 1/4 NPT internal thread, but no standard hydraulic fittings are available to fit a 3/8 hose. A 3/8 NPT would work, but the wall thickness would be rather thin, so I changed the design and used a O-ring seal type fitting with a 9/16-18 thread. This will accomodate a standard 3/8 hydraulic fitting and provides a better seal with plenty of wall thickness, although it takes a little more machining. A PDF version of the drawing is attached.
  • pbynd adapter SAE-6 detail Layout2 (1).pdf
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
2005 International 5900i T/A Flammable Liquid Transport Truck (A55973)
2005 International...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 JOHN DEERE 544K-II WHEEL LOADER (A52709)
2017 JOHN DEERE...
