Power Beyond or HPCO valve help needed
   / Power Beyond or HPCO valve help needed #21
When taking fittings apart, which would you rather clean up before reassembly, paste or tape?
   / Power Beyond or HPCO valve help needed #22
Neither one is difficult to clean up. The people that get in a hurry are the ones who forget.
I just took the Gesen V12 valve apart and built a power beyond adapter to fit it. I posted several photos and a dimensioned drawing in my photo album, Bobs Backhoe on this site. I will put it back together and test it in a few days if the weather holds out. Hopefully this will avoid the problems with too much pressure on the seals of any valve in the system.
The original adapter I built had a 1/4 NPT internal thread, but no standard hydraulic fittings are available to fit a 3/8 hose. A 3/8 NPT would work, but the wall thickness would be rather thin, so I changed the design and used a O-ring seal type fitting with a 9/16-18 thread. This will accomodate a standard 3/8 hydraulic fitting and provides a better seal with plenty of wall thickness, although it takes a little more machining. A PDF version of the drawing is attached.
  • pbynd adapter SAE-6 detail Layout2 (1).pdf
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A56435)
2017 Cadillac...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
13042tx (A55973)
13042tx (A55973)
JOHNSON 5 1/2HP SEAHORSE OUTBOARD MOTOR (A58374)
JOHNSON 5 1/2HP...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
