Power Beyond
/ Power Beyond #1
lekwyo
Wyoming
4200 HST
I have a 4200 which I bought used sveral years ago. It does not have remote hydraulics. JDParts online says the power beyond kit is no longer available for this model. Is it still available somewhere or is there an aftermarket substitute. I have looked online , even on e-bay, and have not seen such a kit. Any suggestions would be greatly appreciated.
Thanks
/ Power Beyond #2
You might give your local dealer a shout. They might be able to track one down at another dealership. Dealer's have the opportunity to check other dealer's inventory and/or network with each other to find obscure or no longer manufactured parts.
Good luck.
AKfish
/ Power Beyond #3
I don't know if this will help, but if you're looking for "Power Beyond Kit" you will probably have difficulty finding it. I just bought this kit for my 2001 JD790 and it's listed as "Rear Auxiliary Hydraulic" kit.
Also, after installing this kit, and knowing what the parts look like, I bet you could probably make a kit yourself. I think I remember reading a thread about someone doing just that. I'll see if I can locate it for you.
TommyJD790...
/ Power Beyond #4
lekwyo,
I just looked up your "Rear Auxiliary Hydraulic" kit on www.jdpArts.com.
There are 2 kit part numbers (MP31353 New) and (MP23146 OLD). These kits look very similar to the one that I bought for my JD790.
You can look at the breakdown of these kits and it will show each piece that's included in the kit. I'm not sure what "new" or "old" means.
I bet if you call your dealer and mention those 2 part numbers, they'd be able to track one of these kits down, or order each individual piece.
There's also a pretty good illustration of the kit on the JDParts website.
TommyJD790...
/ Power Beyond #5
It shows unavailable in JDParts because it is considered a "whole good" and not sold acrossed the parts counter, you will have to talk to a salesmen to order it for you, it should still be available.
/ Power Beyond #6
Tommy, I am not sure where the MP31353 number came from. I found LVB25221 that fits old and new models. It is still available.
/ Power Beyond #7
LEKWYO: Maybe you will be lucky and your 4200 is a lot like the 4100 and 2520. Here is a thread which shows the process and gives the correct JD set screw part number to buy to make it happen. The first few posts are the 3-point details, but eventually the thread gets down to installing power beyond, and does it without JD's "kit". This will save you some money.
http://www.tractorbynet.com/forums/hydraulics/100228-adding-power-beyond-3-spool.html
/ Power Beyond #8
I have a complete kit of the original power beyond lvbm19534, not 5 minutes ago I sent an email quote to a gentleman for $160, if he does not take I will post to this thread again. Box has been opened but I did verify that all items and instructions are with it. The newer kit is available but is $300.
/ Power Beyond #9
oops, looking a little closer to the "lekwyo" name tag and I would guess that you are the gentleman I sent the price info to. Small world !!:)
/ Power Beyond #10
Yup...you're right...:eek:
I was looking at the bottom left hand corner of the illustration.
Tom..
/ Power Beyond
Thanks for all the help. I went to the local dealership to to buy oil and filters for oil change, and I asked about the Power beyond kit. As you can see on the posts the sales manager did happen to have an old kit which he is offering to me at a very good price. My question is what is the difference between the "old" kit and the "new" kit. I think the old kit bypasses the 3pt and the new one doesn't. If I get the"old" kit, is there away to use the 3pt while using the auxillary hydraulics to run say a grapple on the FEL?
Thanks again
/ Power Beyond #12
The new vs the old is entirely in the loop hose. The old hose has a filter in it, the new hose does not.
EDIT: It might be that the new hose has the filter and the old does not.
/ Power Beyond #13
ordered a 2305 last week and I would like to know where they are built they are put togeather in ga. but where does the drive train come from? the dealer does not know.
/ Power Beyond #14
Built in GA? I don't think so...They are made by Yanmar in Japan.
/ Power Beyond #15
I would think they are assembled from parts in the US. That would save them on import tariffs.
/ Power Beyond #16
I need to install power beyond on my JD770 and the part number provided by my dealer is BM18005 and is no longer available. I think I can build one from hydraulic supply store. I think it is just an extension from the scv to the rear looping back to the rockshaft housing. It has a removable hose which must be i9n place to return flow when not using the power beyond (on No7 backhoe) See the hard pipe fitting pictured.
Am I all wet or not?
/ Power Beyond #17
Hi,
newbie here, looking for power beyond for my 790, my dealer has just about given up, he is telling me that he may be able to put one together with
individual parts for between 450 to 500$. I am trying to hook up a new tsc
wood splitter, and this is turning into something far more expensive than
intended. Anyone using the fel to tap into?, too hot??
/ Power Beyond #18
Welcome Hermit!!! Maybe someone with 790 experience will chime in. But if not, maybe we will have you get some pictures so we can speculate about how similiar to more current products the 790 is, so we can come up with a design. Post again in a week to alert me if nothing comes up before.
/ Power Beyond #19
Hi,
Are they looking for BM18005?
They do turn up on eBay every now and then-so you may want to search frequently.
Unfortunately, making your own kit may not be that easy like it is on other models.
You can certainly plug the splitter into the FEL ports and just bungee the joystick over or back to provide constant flow.
/ Power Beyond #20
Reidkearl & Hermit43,
In Dec 2010, I ordered the BM18005 (rear auxiliary hydraulics) kit for my JD770 through the parts counter of my local John Deere dealer here in Colorado Springs, CO (Potestio Brothers). It was $298+tax. It took them about 2 weeks to build the kit and they were happy to do it! It came with directions and I installed it myself.
Reidkearl, the JD parts catalog online doesn't say that the BM18005 is NLA. Perhaps a different dealer would build you a kit.
Hermit43, perhaps a different JD dealer would build you the kit for around $300. The BM18005 kit will work with your JD790.
Bruce
2015 Kubota ZD221 48in. Zero Turn Commercial Mower (A64194)
2015 Kubota ZD221...
2017 Land Rover Discovery Sport AWD SUV (A64557)
2017 Land Rover...
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A64557)
2005 20 Ft...
2019 Ford F-550 Altec AT248F 43ft. Bucket Truck (A64556)
2019 Ford F-550...
2012 Mini Cooper Hatchback (A64557)
2012 Mini Cooper...
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
