Powerstroke fuel pump replacement tragedy?
   / Powerstroke fuel pump replacement tragedy? #21
I just had my Cummins diesel in the shop for a fuel leak problem. When I noticed the leak, I could tell it was coming from behind the water separator, but I wasn't sure if it was the water separator, fuel pump, or what? I kept shining a flashlight and starting the engine until I saw the leak squirting out of a hose where it was clamped to a rigid line. Although I could not find reference to the line anywhere in my maintenance manual, it didn't take a lot of figuring to see it was the excess fuel return line going to the fuel tank. It was a low pressure line. The shop took 1' of hose out of the line and replaced it with new hose and used a piece of rigid tube as a splice with two clamps. The hardest thing was getting to the hose in the tight spot where it was tucked.
I don't know about your Ford, but I'd sure try to put my eye on where the leak is coming from before taking a shot in the dark. It just might be something simple like mine. Good luck with your repair.:thumbsup:
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
UNUSED CFG QUICK ATTACH HYD HAMMER (A51248)
UNUSED CFG QUICK...
KEWANCE 200 9' GRADER BLADE (A51247)
KEWANCE 200 9'...
