Preventing small Well pump house frome freezing
   / Preventing small Well pump house frome freezing #71
I mentioned this prior in page 2 I think, no one seems to listen much tho lol.... simple problem solved long ago but still exploring options I guess lol.
Mark
correct. most people hop into a multi page post and tac on the end without reading the ballance.
   / Preventing small Well pump house frome freezing #72
Basements don't work too well on the Tx (or any other Southern States) Gulf Coast.
When in the US. I was shocked that most homes lacked a full basement. Beats me where they put the utilities, laundry room, freezer , barn washroom/shower, junk room and man's den without a basement ?
   / Preventing small Well pump house frome freezing #73
Plus also many people try to solve problems that are mostly regionalized with solutions that are not appropriate for the area. The climate in N. Texas is so much less harsh in the winter than say Ohio or points north that most of the reply's on this thread are totally off base.
   / Preventing small Well pump house frome freezing #74
One more thing to consider for those with a similar situation, is a battery powered remote thermometer. If the pump happens to be in range of your house, the alarm can be set to warn you if the temp drops below what ever min temp you set.
   / Preventing small Well pump house frome freezing #75
Yep, was surprised to see a reply to my old thread...
Guess I could update too... I have 2 1.5k gal storage tanks by the house with a pump in a small well house. Bought that heater and attached a 220v plug (outlet is inside the well house) so I can unplug during summer. Worked great all winter and temps got down to the low teens.
I've since drilled a well and just purchased another one for its well house.
1991 TRAILMASTER CRUDE TRAILER (A58214)
1991 TRAILMASTER...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
1979 KENWORTH TANK TRUCK (A58214)
1979 KENWORTH TANK...
2016 Jeep Compass 4X4 Sport (A56859)
2016 Jeep Compass...
2007 JLG 450AJ SERIES II SKYPOWER BOOM LIFT (A52709)
2007 JLG 450AJ...
