Price Check Price TC40DA with cab
   / Price TC40DA with cab #21
There's no way you could take the cab off and still have a functioning tractor.
it's integral to the design. (not as well integrated as it should be, but still integrated)
Lonecowboy- If you could buy a tractor under $30k what would it be?
   / Price TC40DA with cab #23
depends on what it's for, what you want out of it?
do you want a cab? (cuz if so, nothing I see puts a cab under 30 grand for anyone).
I like open platform tractors, lighter, easier to see out of it, they feel less tippy (probably aren't, but they feel that way). BUT
since I've gone after this business full time, mowing or working day after day 7 to 10 hours a day, a cab makes a HUGE difference in comfort and how I feel at the end of the day (and if I can get up the next day, turns out I'm not 25 anymore, even if my mind still thinks so ;) ). For me, a cab turned out to be necessary and i was willing to pay that extra money.
For working on my own piece of land once or twice a week, no, I could live without it.
How hot or cold does it get where you are? do you burn easy? (big plus for my wife, she burns easy, and the cab makes a huge difference for her and not burning to a crisp)
How big of property. If you can manuever around a utility tractor, a utility is SIGNIFICANTLY cheaper to run long term than a compact (easier to work on too) but they don't turn as tight.
FEL or no FEL, 4wd or 2wd? (personally, I always get the FEL and 4wd, you never know when you might need it). The TC boomer series FEL's are awesome. great reach, fast reacting, easy to see, and the quick attach is a huge plus. But it's spendy, and if you never are going to need it......
I wouldn't buy a hydro if I had the choice but that's just me, for you and your needs it may be perfect. Expensive and one more thing to go wrong. Kills 5hp too. But, for me and my business, the cab was key and the only way to get a cab in a compact is with hydro (although I do believe if you go green you can do something different, but I don't have that kind of money)
Figure out what physical size tractor you need. Then buy the most horsepower in that size of tractor. That's what i always tell people.
Despite my troubles with the first TC45, the 2nd one anyway is a pretty good tractor. And more importantly it solves my problem quite well. Small enough to move around, big enough to get something done and cab makes a HUGE difference in me surviving each day. I love my NH TN75. I have had zero problems with my Massey Ferguson 1433. (although I should have bought the 1440, same size, more power). My neighbor has a JD 50hp or so and he's had no issues. But he paid a lot for that, a lot more than either blue or red or orange. I think kuboatas are excellent tractors. However, since I"ve gotten older i"ve also gotten bigger and the kubotas are crowded for big guys. But excellent tractors and I never hesitate to recomend one of those to smaller people.
   / Price TC40DA with cab #24
I'll tell you what I gave for my setup as a reference. I paid right at $25,100 for the tractor, loader, canopy and armrests. That was with outside financing and no delivery, but I didn't need either from my dealer. It pays to shop around.:)
   / Price TC40DA with cab #25
35DMAN:
As LoneCowboy states, it's what you're going to do with the tractor that will dictate the price. But, your question as to what to buy for under 30K with a cab, A copule of items I recently looked at during the PA Ag days show:
Kubota B3030HSDC, FEL with quick attach front, 6 ft quich hitch front 6 way dozer blade, 72" MMM, Loaded R4 tires, 30 HP machine, Factory Cab with Air and heat, Hydrostat - all for $27K (ended up buying this one)
John Deere 3320, FEL with quick attach, 72 MMM, Hydrostat, R4 loaded tires, factory cab (note there is no 6 way front quich hitch dozer blade in this units price, which adds about 2,300), 32 HP Unit - priced at $28,500
Kioti 45 HP (forget model #) factory cab with heat and a/c, FEL, loaded R4 tires, I forget what this trans is called, it not hydrostat and it's not manual shift, it has a shift on the go trans, which many people really like, a friend of mine has this type of trans in his 45 hp Kubota. - this priced out at $27,500. Note there is no mower here and they suggest a rear finish mower for this tractor, which is less expensive than a MMM. Also there is no quick hitch front blade here either. This is the largest physical unit of the three.
I mow alot of grass, about 7.5 acre, so the heavier JD and Kioti were a little too heavy for the lawn, both the JD dealer and the Kioti dealer suggested I go with the Kubota due to the amount of grass I mow and the weight of the machine, and since I'm not anticipating lifting over 900 pounds in the loader it also makes sense.
I really liked all three units, and considered purchasing each one of them, but as we started out with, it all depends what you want to do with it.
Best Wishes.
I stuck with the NH. My 35D treated me great. Going to a 40da with NH cab and loader. Can't beat the price and the NH dealer is great to deal with all around. I should have it by the weekend. Thanks.
   / Price TC40DA with cab #27
I paid $26,434.00 total for my 45DA back in January. So, I would say you're gettin' a great deal for the 40. I will tell you that from my experiance this has been one great tractor! I mow 10 acres with it about every week right now in 100+ heat and stay very comfy doing so. I have had no problems at all.
I don't have the loader "yet". But I feel sure I want have any lack of power problems. I've mowed thick pastures head high with a 6' rotary mower and she didn't even bogg down. Good luck with your purchase and don't forget to post some pic's.
   / Price TC40DA with cab #29
35DMAN said:
I just priced it for $24700 with loader and NH cab. $21100 without cab. How is that?
How is it equiped(tires ect)? Just curious, but I assume it is not a SS tractor?
TC40DA, with 250TL loader,cutting edge, supersuite cab -heat/AC/radio, loaded R4s, block htr, grill guard($195 extra). Can't wait!
2023 Power Skid Steer Loader (A50322)
2023 Power Skid...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2013 Chevrolet Cruze Sedan (A50324)
2013 Chevrolet...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
2001 CHEVROLET W4500 12FT FLATBED DUMP (A52141)
2001 CHEVROLET...
2010 DODGE RAM 2500 FLATBED TRUCK (A51243)
2010 DODGE RAM...
