Why was there no noise with the same implement was hooked to another 4x20 tractor.
If the clutches slip even a fraction at each engagement how long will they last before they wear out? How much will that cost?
A bush hog has a big flywheel mass to get going. I always turn my rpm to idle or lower than 1100 to initiate. It is an oil bath clutch so it should last a long time, however if you are initiating a 6 foot bush hog at full rpm, it could put some wear on it. The clutch is very similar to a motorcycle type. You can wear them out too if you like to drag race and slip it a lot. If it grabs hard but squeals, you should be good to go as it is still gripping. Be sure to adjust your bush hog's pto slipper clutch. I only recommend bush hog's with slipper clutches to this type of pto setup.
Oh it does have a clutch on my cutter but my dealer told me to tighten it up till the sound stops. The first time I took it to them he told me my slip clutch was too loose and it wasn't the tractor
Wouldn't need a clutch if there wasn't some slip. Seems to me there has to be slippage when engaging through a clutch. Some wives squeal more than others too.If the clutches slip even a fraction at each engagement .....
