Propane Cost???
/ Propane Cost??? #141
WOW.Same thing here I have offered free wood to folks to heat with and NO TAKERS.Maybe when they get there propane bills things will change.LOL
Around here people are cutting trees along side the road all over.
/ Propane Cost??? #143
2009 they installed a 24" NG pipeline almost in our back yard. Problem is the gas is going from Rockies to the East Coast. Everybody in between is just out of luck. ----------Same here but part of the deal is I got tapped in.
/ Propane Cost??? #144
I see this is the same as gas. When propane shot up, people lowered their thermostats to below 70 to tried and conserve. I'm sure there is some gouging going on, but nobody was prepared for a winter like this. Maybe this summer there will be run on insulation as well. I would had to have my tank topped off at least once if not twice, but I've turned the thermostat down to 64 and use supplement my heat to make up the difference. I've got a kerosene heater that will keep most of the house at 72 or above, and a space heater for the bathroom. And I do plan on adding insulation to the attic and sealing things up better this summer.
Wedge
/ Propane Cost??? #145
Wedge
/ Propane Cost??? #147
Anybody know of a link to average propane costs (nationally) last 5 or 10 years?
David Sent from my iPad Air using TractorByNet
/ Propane Cost??? #148
Just received 64 gallons (100 gallon tank) @ 4.09. This is .10 lower than the last one a few weeks ago.
/ Propane Cost??? #150
I burn primarily wood now instead of lp, saw this coming when prices were 1$ a gallon, now I'm glad I have my wood furnace
/ Propane Cost??? #151
U.S. Weekly Heating Oil and Propane Prices (October - March)
You can also change the Area to a particular state or region (though not Hawaii).
Iowa propane prices have come down:
"Propane prices continued to decline, with the statewide average falling about $2 over the past three weeks to $2.81 a gallon, a new survey today shows."
http://blogs.desmoinesregister.com/...allon-new-survey-shows/article?nclick_check=1
/ Propane Cost??? #152
No West Coast either...
It's been eye opening just seeing how low prices are in parts of the country.
/ Propane Cost??? #153
A buck a gallon! How long ago was that??? I paid under 2 late last year but don't remember when that was the price delivered. But senility might be setting in.
/ Propane Cost??? #154
Well not exactly a buck, around 130 just a few years back, I figured as high as it is now why bother typing the .30. Lol
/ Propane Cost??? #155
I believe it was $1.65 here last summer. Do you think we should start "hoarding" propane?:D (I would if I could:eek:)
/ Propane Cost???
There was a brief time last Summer when it was .99 here in Northern Missouri.
/ Propane Cost??? #157
What you do is buy a tank which will hold the total amount you will possibly need in a year and refill each summer. The second best is to do a summer fill and get a contract for the full amount you might possibly need.
/ Propane Cost???
It was proven here that the contract only has value in the bathroom if you are desperate.
/ Propane Cost??? #159
Yeah I think I made a tactical error last year when I finally got fed up with my leased tank and provider and bought a tank and switched companies. I got tired of paying $60/year rental and stuck with paying their high prices since no one else could fill it. I had a 500gal tank and downsized to 250gal to save some upfront cost and thinking I could shop around and always get best price. Luckily it is not my primary source of heat. Use for local heat (living room and home office) and cooking.
Just have to conserve until prices come down this spring. Under 20% now though... what happens if you run it dry? Does this pose any problems other than just having to purge the lines? Is this a concern?
/ Propane Cost??? #160
I am afraid that "slick paper" is not ideal for bathroom duty. Apparently that paper is not good for much of anything.:)
2016 International Workstar 7500 T/A Dump Truck (A61573)
2016 International...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A61573)
1987 International...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
Ford 8210 (A60462)
Ford 8210 (A60462)
2017 FREIGHTLINER CASCADIA  6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2017 FREIGHTLINER...
2019 Caterpillar 349FL Hydraulic Excavator (A61572)
2019 Caterpillar...
