Propane Tank Location
   / Propane Tank Location #1
CurlyDave
Elite Member
Grants Pass, OR
JD TLB 110
Is there any minimum separation distance from a propane tank to a house, or to a heat pump outside the house?
Around here, the propane companies want the tank to be within 75 feet of a drivable surface for their truck, and I think I have a good spot, but it is only 15' or so from the house and from the heat pumps.
Propane is heavier than air, and unfortunately the location I have in mind is above the heat pumps. Does this make a difference?
What is the maximum distance? Can I put it say 200' feet away if I want to?
   / Propane Tank Location #2
Dave,
I am not sure of any codes, but I have observed them very close to some homes. All of the problems I hear about are up in the deep snow areas. Something breaks on the tank and propane collects under the snow until it finds a source of ignition.
Another consideration would be defensible space to battle a wild fire. So don't plant the tank in a thicket of brush. I can imagine you might be in a forested site, so trees should be thinned to 10' to 15' apart in that defensible area.
Jim
   / Propane Tank Location #3
I believe around here the minimum distance is 10'.
As far as why the propane company wants it 75' from the driveway - that is how much hose they have. Gonna be a little bit hard to fill if they can't reach it. Other than that, yes, put it where you want it. The other thing to consider is if you get too far is the cost of the copper line itself. I know in the big picture it isn't much, but all of the little things can add up. For 200' of copper, you are probably looking at $5 - 600 + the trenching.
I don't know about the tank above the heat pump. Wouldn't think it would hurt anything. Chances are if there were to be a leak, it wouldn't be from the tank but from the line in the ground due to rocks or corrosion.
FWIW, my tank is about 40' from the driveway. Was closer to the 75' mark but we extended the driveway when we built the garage. Our propane tank is 75' from the house and only about 10 or 12' from the garage. Tank was there first.
   / Propane Tank Location #4
There is a minimum distance to a structure though I can't remember the numbers. Your Propane dist. would have that info. I drove for a local propane dealer one winter(good incentive to find another career). I would ask this: PLEASE put the tank close to a solid, well drained area (right next to your driveway with asphalt right up to the tank would be nice). I had a touch over 100' of hose on my truck and it gets HEAVY, expecially slogging through a wet East Texas Winter yard. There were houses I hated going to because I had to drag all the hose out to get around the shed, over the garden spot, through the rose bushes and over the trellis covered w/ some thorny vine to get to the tank. Usually only to find that there was a man-eating something chained to the tank itself. Please be kind to your propane delivery man!
   / Propane Tank Location #5
   / Propane Tank Location #6
Just went thru this with our gas company (only one) last week. They gave me same diagram as page 44.
David
   / Propane Tank Location #7
Santa Clara county has a 10-ft minimum, and a concrete pad
requirement. How far away your tank is will determine if you put
your pressure reducer at the tank or at the house.
BTW, I bought a vertical tank from a dealer in WA, and it was shipped
from the manufacturer in OR to me here in CA. This was a 120 gallon
tank that I could install myself, vs the cigar-shaped tanks that take
special craning equipment.
   / Propane Tank Location #8
Has anyone used a buried propane tank? For our property, I was hoping to do this (and keep it close to the drive for ease of filling).
Planning for the excavation at the same time as other major excavations should help keep the costs down.
   / Propane Tank Location #9
Undergrounding of LP tanks not allowed here. Maybe not allowed
in other parts of CA, too.
   / Propane Tank Location #10
Afternoon Dave,
As the others have said, 10ft sticks out in my mind ! I ended up going about 40 ft off the back left corner of the house to get me to the tree line and kind of outta sight ;) Although after reading Jims post I better get out there this spring and thin those small trees out just a bit ! I was planning on adding on to the back of the house at some point and that was another reason to go that far back. But yes, 10 ft is what I was told for minimum distance.
   / Propane Tank Location #11
I just went through the whole ordeal of choosing a propane company, and having my tanks set. Here in Maryland, can't speak for any other part of the country. If I initially wanted a 500 gallon propane tank, it would have to be set 10' from the structure and 10' from the property line. In my case only having 15' behind my building I could not use the larger tank. So I opted for 2 of the 100 gallon tank, these tanks are roughly 5' tall and about 3' in diameter. They can be set right next to the building. I made a gravel pad, with concrete pavers. The propane company was just going to set them on 3 cinder blocks laid on there sides. The tanks also had to be 10' from the exhaust, which goes through the wall. And they want the tanks within 100' of were the truck could park. I had one guy that wanted me to put the tanks real close in a spot I did not want them in. Were I wanted them was about 60' feet away, he gave me a boat load of crap, so I told him to take a walk.
See attached pictures for reference only. First is the 500 gallon tank, second is the 100 gallon tank (420lbs)
Bill
   / Propane Tank Location #12
I have a guy from the Texas railroad commission standing near me (they regulate propane co's in Texas) here is the code: under 1000 gal. min. 10 ft. from a structure, Over 1000 gal. min. 25 ft. Underground tanks ANY SIZE 10 ft. min., Under 150 gal. have no min. setbacks.
Jack
Wow!
10' seems very, very close to the house for that much propane.
Since I have 700' to a property line, I will put the tank a bit further from the house, at least 25', but I won't worry about it.
I checked prices today and a local company wants $1800 to sell me a 500 gallon tank and $75/ year to rent one. 1000 gallon rents for $100/year.
Now, if I take that $1800 and put it in the bank @ 5%, I can get $90 per year interest, so I think I will be renting the tank.
I think I would prefer a 1000 gal one just because we are at the uphill end of a steep road. Two cars went off the road last week when it snowed. I would hate to run out of propane in the middle of a snowstorm when no trucks could get up the road.
How heavy are these tanks? Why can't I just pick one up with my FEL and put it where I want it?
   / Propane Tank Location #14
Mornin Dave,
I dont have an answer on exactly how heavy the tanks are. When I bought my 330 gal tank from the farmer up the road, the tank was half full, so Im guessing I had at least 150-170 gals in the tank at that time. He has a 60 hp JD and he just barely lifted the tank up to get it on a trailer to tow to my house.
   / Propane Tank Location #15
Don't know about California. But we buried our 500 gal tank with no problems.
   / Propane Tank Location #16
Sunshine Propane
according to that a 250 gallon weighs in at a hefty 540lbs
a 500 gallon is (guess what) bout twice as much 1060
and a 1000 gallon ~ twice that.
so ya if you can hoist around 1000lbs pounds with your FEL ya you can. (i was going to buy a couple of 250 gallon from various private party's and move them myself....)
   / Propane Tank Location #17
what your missing is what you might end up paying as a "gocha" preiumum on your gas price as other dealers will not fill up tanks you lease from someone else.
so knowing your stuck with bubba's gas service he tacks on $.25 a gallon because he can. :cool:
   / Propane Tank Location #18
schmism said:
what your missing is what you might end up paying as a "gocha" premium on your gas price as other dealers will not fill up tanks you lease from someone else.
schmism's point is valid in this area. My propane co. of choice ONLY sells tanks. No rentals. 20 years ago they sold their previous propane business to CalGas, then opened another.
Their price now is always the lowest in the area (I occasionally check). They explained that renting tanks cost them a bunch, mostly on rented homes. The people wouldn't pay the bill but it's illegal for them to confiscate the propane or tank, so they'd lose the money.
So for their new company: NO tank rentals. And because of that, lower propane prices. And I CAN get my propane from any company although I never have.
Phil
I am aware of the issue.
Right now, when I don't have a propane tank, or even a finished house, everyone is quoting very competitive rates. About $0.10 above what the gas stations with propane charge. Certainly the delivery is worth that much.
Fortunately, in Grants Pass, there are numerous gas stations which also sell propane and post their prices prominently. There is no doubt on the best price in the area.
If & when a supplier wants to charge more than a nominal markup over the posted price, I will simply get a friend or neighbor to call & ask about prices. If they quote a "come-on" price to someone else, I can be pretty assertive about wanting that price myself.
Although, most of the people I have met get their gas at competitive prices, even with rented tanks. One of the advantages of the free market & several hungry delivery companies.
   / Propane Tank Location #20
Dave,
I like your thoughts about the rental fee vs keeping the $1,800 and earning interest on it, effectively earning enough to pay for the annual rental. Net effect is you get your tank for free and have more to spend on fuel. So if your captive gas company charges you say 10¢ more per gallon, you would could use about 900 gallons a year before it actually starts to cost any more.
On the other hand, if you were to spend the money and buy a tank for $1,800 you'd have to amortize the cost of that tank over the gallons you buy. For example, IF YOU SAVE say 10¢ per gallon, it would take 18,000 gallons to break even. Or about 900 gallons per year for the next 20 years. Excluding service and repairs, if any.
Just something to think about...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A59231)
2009 Mariah SC23...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
3650 (A47477)
3650 (A47477)
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
