Proper Wheel Torque? NH manual gives 2 specs
/ Proper Wheel Torque? NH manual gives 2 specs #1
sweep
Ohio hill country
2006 TC45A
I have a TC45A. On page 3-27 of the owners manual it says front & rear wheel torque is 95 foot lbs.
The specification page it says the front & rear wheel torque is 125 foot lbs.
Which one is correct?
/ Proper Wheel Torque? NH manual gives 2 specs #2
I think my 2120 calls for 137 - 159#. 95 is more in the car range, so I'd go with the higher torque, as the bolts are bigger than a car's. 2120 is only a bit bigger than yours.
Jim
/ Proper Wheel Torque? NH manual gives 2 specs #3
My 2120 calls for 137 - 159#. 95 is more in the car range, so I'd go with the higher torque, as the bolts are bigger than a car's. 2120 is only a bit bigger than yours.
Jim
/ Proper Wheel Torque? NH manual gives 2 specs #4
Page 3-27 in my older TC45D manual from 2001 says the torque for both front and rear wheel lugs is 125 ft-lb. I think that's your number.
I set the torque wrench to 125 and it clicked. Went up to 130, clicked.
Set it at 145 and it clicked and I stopped there
There was no movement at those settings.
I figure the dealer or the factory did not want them to come loose anytime soon.
UNUSED X-STAR 250 GALLON FUEL TANK W/ FORK POCKETS (A60430)
UNUSED X-STAR 250...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A60429)
2016 CATERPILLAR...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
UNUSED IRMC HIGH END MASSAGE CHAIR (A60432)
UNUSED IRMC HIGH...
