pros and cons to running a 4WD tractor in 2WD
   / pros and cons to running a 4WD tractor in 2WD #54
Whenever a wheel starts to slip, it goes into 4wd. To save wear and tear I like 2wd. All winter, even with chains I use 4wd- always in and out of deep snow.
   / pros and cons to running a 4WD tractor in 2WD #55
You will learn a real "con" of running a 4WD tractor in 2WD, when you go down a steep hill with a load in the front bucket and not a whole lot of weight on the 3pt. You will learn it the hard way, and you will never do it again.:eek:
   / pros and cons to running a 4WD tractor in 2WD #57
One thing to be aware of is that most tractors (if any) don't have front brakes. If you don't have enough weight on the rear of your tractor (no ballast in the tires and a light or no attachment) you could find yourself quickly in trouble going down a hill. The rear tires will just skid offering you no braking force. Normally I leave my tractor in 4wd unless I'm on pavement or if I'm trying to protect lawn from being torn up.
Me too... I run in 4WD all of the time unless I am on pavement. There is so much more control IMO when in 4WD vs 2WD. I am generally on a slope and the few times early on when I forgot to put it back in 4WD I lost control going down hill even with brakes. I started sort of hopping. Not sure exactly your question but if you are worried about a 4WD tractor health running in 2WD... no issue. It your own health to be concerned about.
   / pros and cons to running a 4WD tractor in 2WD #58
I leave mine in 2WD unless I'm using the loader or needing some extra traction. Making tight turns is so much easier in 2WD. Only takes a push of the lever to change 2WD to 4WD, and back.
   / pros and cons to running a 4WD tractor in 2WD #59
in to the mud 2w drive out of the mud 4w drive. prevents me from getting good and stuck
   / pros and cons to running a 4WD tractor in 2WD #60
A flatlander may get away with 2 by but on the hills you're just asking for trouble- as others say.
2006 BIG TEX 16 T/A TRASH TRAILER (A55745)
2006 BIG TEX 16...
HYSTER P200B ROUGH TERRIAN FORKLIFT (A55745)
HYSTER P200B ROUGH...
1996 Timpte 46ft Hopper (A55315)
1996 Timpte 46ft...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
