pros and cons to running a 4WD tractor in 2WD
   / pros and cons to running a 4WD tractor in 2WD #61
A flatlander may get away with 2 by but on the hills you're just asking for trouble- as others say.
In the MS Delta its all flatland! Having a 4WD is almost mandatory in that gumbo if you gonna get any tractor work done!
   / pros and cons to running a 4WD tractor in 2WD #62
There is no real difference between 2wd v 4wd on your tractor or on your pick'm up truck. I'm in 2wd until I start loosing traction in 2wd. Then I'm in 4wd. When I regain traction on more solid ground, I switch to 2wd. Less wear and tear, less fuel, better turning radius.
   / pros and cons to running a 4WD tractor in 2WD #63
SAME FOR ME>
   / pros and cons to running a 4WD tractor in 2WD #64
SAME FOR ME>
2013 Husqvarna LGT2654 54in Riding Mower (A55853)
2013 Husqvarna...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2025 Swict 72in Bucket Skid Steer Attachment (A55851)
2025 Swict 72in...
