Proud New Owner of YM1610 2WD
   / Proud New Owner of YM1610 2WD #61
Google "diesel slobber" and/or "wet stacking". the real fix is usually overhaul.
   / Proud New Owner of YM1610 2WD #62
Just a couple of questions from old curious Winston. What rpm do you normally operate at? Is your temperature gage getting up at least a quarter of the way? Certainly not saying it is the problem but just putting it out there as one cause is leaking injector.
   / Proud New Owner of YM1610 2WD #63
id be willing to bet that there is water leaking in that exhaust from rain, unless its kept in a shed during all rain events then that shoots that one?
   / Proud New Owner of YM1610 2WD #64
fwiw, it takes a while to get moisture out once its in,get it hot, if its not losing a-freeze it should improve as u use it-did u change the engine oil ? if not see if its real thin on the dipstick
   / Proud New Owner of YM1610 2WD #65
Unbolt the Exhaust and move it so that it's pointing Fwd. You can also put a 45 deg. on so that it would be pointing downwards. That will keep water from getting in the exhaust while sitting and if it is Oil/Fuel Blowby you may get some on your feet.:2cents:
NEW Woods 6ft Finish Mower (A52748)
NEW Woods 6ft...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
