MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,250
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I'm thinking keep it simple. Pressurizing the tank and then keeping it adjusted would be tough. What if you attach an implement like a back hoe, then extend all the rams out? You'd probably lose enough volume in the tank to set it off.What if we were to mount something like the Subaru tire transmitter, and pressurizes the tank, and when when full, max air pressure, no signal, but when tank is one half full of fluid, less air, a signal is transmitted to the dash, and maybe shut off the engine.
I'll bet a float switch would work well. For a slope mower, you could put two switches in, at opposite corners of the tank and wire them so both would have to be low at the same time to trigger it. Since the oil can get very hot, we need something rated for that heat as well. That's why I'm tending to lead towards something that is already made to be immersed in hot oil.
