PTO drivetrain to 3/4" round shaft with 3/16" keyway - questions
   / PTO drivetrain to 3/4" round shaft with 3/16" keyway - questions #11
I designed a system like this but never finished building it.
Mine was to power a water pump.
I took the PTO drive shaft on my brush hog since it had a round shaft.
Then I bought a piece of DOM tube with a 3/4 inch hole in the center
and with an outside diameter to fit in the PTO drive shaft.
I planned to weld the DOM tube to the 3/4 shaft and drill a hole
thru both of them to accept the shear bolt for the brush hog.
Maybe this will give you an idea.
Get a piece of DOM tube to fit a PTO drive shaft you have,
then drill and tap a hole all the way thru it to accept a short bolt
from both sides. You could get a keyway cut into your "bushing"
and let one of the bolts hold the key in place. Works in theory anyway.
Pooh Bear (aka Fluff For Brains)
   / PTO drivetrain to 3/4" round shaft with 3/16" keyway - questions #12
SPYDERLK said:
Hub City doest seem to list a spline to round bore bushing like Todd described. That would seem an ideal solution.
larry
Sure they do- part number 0332-00408 then you use part number 0332-00394 a double male 1 3/8 spline or 0332-00356 if you want the grooves for the quick pin, to plug into the PTO coupling......
In effect one has created option 2 of denisd's post....
Or he could use the adapter from option 1 with a double male spline.....
Besides the one at Hub City, Surplus Center offers this one- Surplus Center Item Detail although it might be a little long depending on how much room he has. The Hub City one is 3" shorter....and if one wanted he could cut the Hub City full spline one (0332-00394) to the shortest length possible if a means to secure it can be used.
   / PTO drivetrain to 3/4" round shaft with 3/16" keyway - questions #13
This puts an extended assembly on his winch shaft and bearing. Not like a bushing which could be made to add no length. Pooh Bear almost made one - Todd bought one at NAPA. That would be my 1st stop.
larry
I need to go into the NAPA store and see if they have PTO adapters. I hesitate to special order there. Most people I talk to don't grasp this application as well as you guys have.
I see the 10" splined shaft now, thanks. I could cut it down to where the parts butt.
It still does start getting tight in the 24" space I have between tractor and winch. Driveline assembly + 10" splined shaft + snap hitch adapter. But that's an option (1).
Pooh Bear's very clever tubing idea (custom, like option 2) eliminates the adapters. The interior keyway cutting would incur a machine shop minimum charge, which still might be less than the two adapters. But I still need a U-joint at the winch end.
A machine shop could make the adapter (option 2) by taking that 10" splined shaft, bore it 3/4" and cut a 3/16" keyway, probably at the same charge.
For replacing a yoke (option 3), I see what you mean about matching a yoke to a driveline. They're all different sizes of ear width and ear hole ID. The yoke at Partsco gives only the ear outside width.
One supplier, Advanced Drivelines, quoted $190 plus freight for a complete driveline including the 3/4" round keyed bore at the implement end. That's starting to sound pretty good...
   / PTO drivetrain to 3/4" round shaft with 3/16" keyway - questions #15
However you end up, if there is no other overload protection in the driveline, consider using a brass key rather that a steel one on the 3/4" winch input shaft. I suspect that your tractor pto, even at idle, produces enough torque to damage the winch if you tie into a large load. If a brass key shears and the winch is not damaged, then perhaps a steel key of 1/2 the coupling length could be tried, etc. Brass keys are available from most marine supply houses, and you can probably find one online.
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2016 Ford Escape SE SUV (A55853)
2016 Ford Escape...
