Pto problem...
   / Pto problem... #1
Revron
John Deere 4500
Jd 4500::while using bushhog when I get in thick grass such as the road grass I call it, pto stops...shaft and all.. the manual says not enough rpm on tractor..give more rpm..what do y’all think?
   / Pto problem... #2
I dont. LOL
   / Pto problem... #3
That does not sound correct to me. If the engine stays running but PTO stops, something is slipping.
   / Pto problem...
Thank you...my thoughts exactly..thanks
   / Pto problem... #7
Sounds like either low pressure or a worn out clutch. You can check the pressure with a 300 psi gauge and a 1/8" male pipe adapter. Pressure should be around 218 psi. If low, you can check orings on solenoid, or possibly defective solenoid. If solenoid and orings are good, then cliutch needs to come out and rebuilt. If pressure is good, then clutch needs rebuilding for sure.
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
2003 Big Tex 10PI...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
