Pulling A ''Loaded Trailer'' behind A Ballast Box ??
   / Pulling A ''Loaded Trailer'' behind A Ballast Box ?? #1
JohnDeere4300
John Deere 4300
My Ballast Box weighs 1381 lbs. and since I use my QH, That would add about 65 lbs...So 1446 lbs. on my 3PT Hitch.
I've been hauling firewood in the past couple days, and using my homemade log/trailer hitch to pull my homemade firewood trailer.... Also, The log/trailer hitch doesn't weigh much at all... Probably not over 170 lbs.
I don't know how much my firewood trailer weighs empty, But when loaded with wood it's kind of heavy!... Especially pulling up the hill loaded!!!
Question:
If I pulled the firewood trailer behind my Ballast Box... Would that be ''too much weight'' for my 3PT Hitch ??
I have a steep hill to go up and down when hauling firewood... When I have my log/trailer hitch on and have to pull the empty trailer down the hill, I don't have enough traction on my rear tires!!! :)... I have forgot to put my tractor in 4WD a few times and slid all the way down the hill! :eek::D... I go down the hill in 2ND gear!
If we get any rain.. I don't haul wood because the hill gets slick!!!.. Been-there done that!!! :)
So what do you all think about pulling a loaded trailer with the Ballast Box on ??
Thanks!!!
Here's some pictures...(a couple of old pictures from 2010 showing the log/trailer hitch)
Bill
   / Pulling A ''Loaded Trailer'' behind A Ballast Box ?? #2
   / Pulling A ''Loaded Trailer'' behind A Ballast Box ?? #3
I have a box like that and it will change the point of connection further back, and I had trouble with the trailer wanting to jacknife me going down a hill. It can really push the front back and forth because of where the trailer coupler is, so far behind the tractor. Just a thought ..
   / Pulling A ''Loaded Trailer'' behind A Ballast Box ?? #4
Looks like you've been doing this for a while...with no apparent problems (other then the wet grass slip n' slide)...I can't see any reason to not continue what you're doing, can you?
Question for you...is the hitch on the ballast box butt welded?Or, did you cut a hole in the box for a more substantial weld? Just curious...
   / Pulling A ''Loaded Trailer'' behind A Ballast Box ?? #5
If it were me and wanted more weight on the rear tires I would move the trailer axle rearwards instead. Shifts more weight forward and forego the ballast box hooking up to the drawbar.
Working in the woods gathering firewood it would seem a front box made to fit your forks and a rear carryall would be easier to handle than a trailer and would haul about the same amount.
   / Pulling A ''Loaded Trailer'' behind A Ballast Box ?? #6
I think aczlan and I think alike. :laughing: I was gonna say if your 3 pt can't lift combo of ballast box and loaded trailer then you shouldnt try to pull it.
Should be ok as long you always keep in mind that there is a greater leverage fulcrum point being moved further back with ballast box on.
   / Pulling A ''Loaded Trailer'' behind A Ballast Box ?? #7
If nothing else, you have an emergency brake by dropping the 3 point.
   / Pulling A ''Loaded Trailer'' behind A Ballast Box ?? #8
You have an unusual hitch & crane that moves the hitch back quite a bit in the first placce. This hurts you on the hill.
The weight box will add more traction, but move the hitch back farther yet. Might come out even, but you have a real jack-knife setup there.
I think a lot depends on how you load the trailer - more weight up front, or about balance weight....
-->Paul
Yeah, Been doing it for years!!!
I just need some more weight on my rear wheels so I don't ''slip-n-slide''!!!:)... If I use the log/trailer hitch to pull the trailer, then go down the hill empty and forget to put the tractor in 4WD... The tractor will slid all the way down!... It won't if I use the Ballast Box even in 2WD.... This is the first year using the Ballast Box while working on firewood!
I have pulled a loaded trailer up the hill, and get to the top and the tractor slides sideways in 4WD!... That's happened several times trying to haul wood when the hill is wet!... I had to hook my truck to the tractor to pull it on up, Because I didn't want to back off the hill!!!:D
Just thought I would ask about using the Ballast Box since it weighs a lot, and puts the trailer way back behind the 3PT hitch!
The hitch goes all the way through and welded up good!
Here's a picture:... (This is the ugly part of the box!):)... It was hard welding down in the box because it's 2'x2' and 2' deep!... Hard to stand up and reach down to the bottom to weld it, and the smoke and arc flash was bad!!!... Had to watch out and not burn a hole through the bottom, Because I used 1/8'' metal to build the BB.
I didn't try to clean my welds up on the bottom, Because concrete covered it all up!:D
The hitch is welded to a railroad plate, and the RR plate is welded to the bottom... It also has 2 pieces of angle iron that's welded to the front part of the box with a piece of flat-bar under the angle iron!... I wanted to make sure it was welded up good so it wouldn't pull out!
Bill
The axle is moved forwards so I can pull it behind my ATV and not have too much tongue weight!... I've tried just hooking up to the draw-bar, But it didn't help much because of where the axle is now. ??
This winter I'm going to turn the trailer into a dump trailer... Build another bed and have 2 axles!... So after I do that, The trailer would weigh more and I could probably use the draw-bar!
I've thought about a carryall and a box for the forks! :)
When I go on my trails out in the woods... I leave the trailer out in the bottom and just take my forks, log hitch and BB... I then bring the trees out in the bottom and split them there, and then have to haul the split wood up the hill!
I've been trying to stack all the wood on pallets, But the pallets don't work out right in the woodshed!... I can't double stack them.. I'm thinking about not using the woodshed since I would be using pallets, and just cover the tops up with plastic!
Thanks for the reply!
Bill
TANK MANIFOLD (A55745)
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
