Pulling roots
/ Pulling roots #1
rolloff3
morristown nj
ford 1910
I recently cleared a field of oak and fur trees buy pushing them over with an excavator . Now I have lots off roots to clear above and below the surf use . What is the best 3 point attachment to clear the roots? Thanks Pete
/ Pulling roots #2
your best bet would have been to keep the excavator a little longer I think...!
Other's here may have a better suggestion, but all I can think is that you need to deep plough (moldboard plough) to get the rest of the buried root to the surface, and then try to collect the bits with a land rake or similar...
:welcome:
/ Pulling roots #3
Do you have enough tractor power to use a multipoint ripper bar?
I've used both a single shank ripper and a bucket tooth bar to dislodge broken roots before.
Caught plenty with both a rototiller and moldboard plow too but not intentionally :D
/ Pulling roots #4
I use the rippers on my boxblade. I set them deep and usaully turn them in reverse and backup,not always,but its easier to push the roots up in a pile and clean your rippers out if there backwards. Hope this helps. LUTT:thumbsup:
/ Pulling roots #5
Thank you, LUTT, above. I will try turning around the rippers on my box blade. I have a lot of roots to pile up too.
A good tip.
/ Pulling roots #6
A good tip.
Your welcome! LUTT
/ Pulling roots
:welcome:
Thanks for all the responses with some great suggestions . I'm new to this site and I'm glade I found it. Soon as the weather breaks I'll give some a try.
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
Informational Lot - Shipping (A63688)
Informational Lot...
2012 Ford E-450 Sewer Viewer Van (A61573)
2012 Ford E-450...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
Atlas Copco Air Compressor & Air Dryer (A62613)
Atlas Copco Air...
211299 (A62131)
211299 (A62131)
