Pulling roots
/ Pulling roots #1
rolloff3
morristown nj
ford 1910
I recently cleared a field of oak and fur trees buy pushing them over with an excavator . Now I have lots off roots to clear above and below the surf use . What is the best 3 point attachment to clear the roots? Thanks Pete
/ Pulling roots #2
your best bet would have been to keep the excavator a little longer I think...!
Other's here may have a better suggestion, but all I can think is that you need to deep plough (moldboard plough) to get the rest of the buried root to the surface, and then try to collect the bits with a land rake or similar...
:welcome:
/ Pulling roots #3
Do you have enough tractor power to use a multipoint ripper bar?
I've used both a single shank ripper and a bucket tooth bar to dislodge broken roots before.
Caught plenty with both a rototiller and moldboard plow too but not intentionally :D
/ Pulling roots #4
I use the rippers on my boxblade. I set them deep and usaully turn them in reverse and backup,not always,but its easier to push the roots up in a pile and clean your rippers out if there backwards. Hope this helps. LUTT:thumbsup:
/ Pulling roots #5
Thank you, LUTT, above. I will try turning around the rippers on my box blade. I have a lot of roots to pile up too.
A good tip.
/ Pulling roots #6
A good tip.
Your welcome! LUTT
/ Pulling roots
:welcome:
Thanks for all the responses with some great suggestions . I'm new to this site and I'm glade I found it. Soon as the weather breaks I'll give some a try.
2023 Case TV380 (A62177)
2023 Case TV380...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
