scott_vt
Super Member
- Joined
- Oct 5, 2004
- Messages
- 7,382
- Location
- east wells,vt
- Tractor
- 1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
bcarwell said:All GREAT advice. This forum is terrific. Gotta digest it all and will be back. In meantime, a guy at work said for centrifugal or 'suck' pumps, physics says if you have even a perfect vacuum, the most you get is air pressure 14 psi and you won't be able to get up 60 feet. True ?
Farmer Bob
Hi Bob,
I have to jump into this conversation, not because Im a pump expert, I am not. But your buddy at work is misunderstanding you or you him.
Let me start by saying I have been a volunteer fireman for just about 25 years. Most all FD pumps are centrifugal. Years ago before we had porta tanks and all these modern conviences we used small billy pumps in the woods for pumping from small ponds and streams to wherever the fire was. These pumps were all centrifugal for the most part. They could LIFT the water, meaning they could suck the water to the pump anywhere between 5-10 ft elevation. But they could pump that water up some incredible elevations to the fire ! 100 ft or more was not uncommon! Our pumper trucks could do the same thing but on a grander scale !!!
I think your friend at work meant that there are limitations on the amount of lift, sucking as you put it, for any type of pump ! Whether it be a small portable or larger pump as on a truck.
One other thing, you obviously need hard suction hose to get the water to the pump .
