Pumps, flow and restrictions.....
   / Pumps, flow and restrictions..... #21
The best way to see this in action is watching Flow/pressure thru a High Pressure Flow Meter with Load valve inline on a positive displacement hyd pump......you can vary the resistance load while tweaking the valve watching flow basically stay the same (excluding efficiency factor of the pump )....:thumbsup:
If we are assuming pressure will be the same, flow would have to decrease cause restriction would either have to cause a pressure increase to get through the same amount of flow to do the same amount of work.
That is all correct!! But in my example flow cant decrease....it is "fixed", so increased pressure is what it takes.....
I will make an analogy for you.....you are pushing your car on the pavement.....not very hard to do.....car rolls into deep loose gravel....what does it take to keep pushing with the same speed (fixed pump flow)??.......just push harder !!! Higher pressure is what it will take to push fluid through a decreased orifice (restriction)....
Constant flow systems have variable pressure to regulate/control out put power...
Constant pressure systems (like the water supply to our garden hose), have constant pressure and variable flow to regulate/control the out put power
(A load sensing system can vary both flow and pressure to regulate/control out put power)
When the PRV, in the constant flow system, start by-passing/diverting flow, a constant flow system will start acting like a constant pressure system, and it will be possible the decrease flow with a restriction/orifice...
Of course in reality, there is internal leakage in pumps, valves seals etc....that will divert some smaller amount of flow, if a restriction increases pressure. Prime mover might also bog down a few rpm's from pressure load....but over all... in constant flow systems, my point is still, that it is not accurate to say flow increases if we use larger fittings, hoses etc....but we will indeed increase supply pressure, to keep flow constant....
There is a common misunderstanding that a hydraulic flow, at any time, can be varied with a variable restriction/orifice....that can actually only happen when part of flow can be diverted.....(internal leakage, PRV by-pass etc
The diverted flow by the pressure is all entirely a power loss.
Great idea!!
If some one have a Hedland inline flow meter and a pressure gauge, it would be pretty nice to see a live video clip on this.....:thumbsup::thumbsup:
   / Pumps, flow and restrictions..... #24
If I could get off my duff and figure out how to use "Youtube" then I'd do it....think my largest one is 100 gpm/6000psi.....
Maybe a Youtube/Google Search will find one:anyone:
Well you start shooting the video, and I will help you with Youtube later....you also probably will need to edit and save video in a Youtube friendly size and format....I use Windows Movie Maker, WMM, for that...It is included in later version of Windows....I use win7 now, and I had WMM in my Windows Vista....do not remember about earlier versions just now...
But 100GPM is a BIG flow meter, to belong here at TBN....LOL....how did you come across that one???
Hedland flow meter on Youtube
   / Pumps, flow and restrictions..... #26
how do you know temperature and viscosity is very critical at calculations of flow, when you do not know how to make the calculations?? LOL
Some 45 or so years ago I saw a book on "Fluid Dynamics" in the library. Even the symbols they used had me confused. I was using the book to sit on so I was higher and had a better view around the library!:thumbsup:
AKK: Think I have answered your question at least twice now.:laughing: Maybe an empirical test is in order.:thumbsup:
So you mean you almost stuffed it up your bu**??
I think you read that book front to back multiple times, and then slept with it under your pillow.....Hhahaahah
I hope one of the younger "shop guys" will accept the challenge and make a video documented test....How about Sweden-Art, Design Engineer??
You did good Egon!
I know you have done your home work many times....:thumbsup:
You deserve a break now!!
I think I can "trigg" you soon again though....hahahaha:D
   / Pumps, flow and restrictions..... #29
Gotcha!!:thumbsup:
   / Pumps, flow and restrictions..... #30
One of a few in my collection that started years ago when the guessing game of "Eyeball Detective" dictated a need for positive proof for troubleshooting these wonderfull things called hydraulic pumps.....Nothing beats seeing flow rates and pressures with your eyes and not your "Best Educated Guess".....:laughing:
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
Rooster Weathervane (A55853)
Rooster...
Quick Attach Skidsteer Hyd. Angle Blade (A59814)
Quick Attach...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
Enmark Z Spray (A53316)
Enmark Z Spray...
2018 JOHN DEERE 323E SKID STEER (A60429)
2018 JOHN DEERE...
