Punctured My Fuel Tank
   / Punctured My Fuel Tank #21
Are you going to build a steel plate to help protect that area? Now that it is patched even a weaker stick might re-puncture that spot again and cause your more problems.
   / Punctured My Fuel Tank #22
Mine only has the 'hood' tank. Holds about 20g ( may be closer to 19g.. ?? )
I don't put to much faith in my fuel indicator. I have all but run out of fuel with about 1/4 showing on the gauge.
I make a habit of refueling the tractor when iput it away for the day.
Soundguy
Yes, I will fabricate a protective plate to protect the tank and fuel pump.
Attached is a picture of the offending stick, which is actually a small tree, roots and all. I don't know whatkind of tree it is, but boy is it a tough little bugger!
Here's a side shot of the root that punctured the tank. I could smell the deisel fuel still on it.
The proud Green Beast prepares to drop her nemesis on the burn pile. /forums/images/graemlins/grin.gif
Guess which burn pile I'm gonna light first in October? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Hehe!
   / Punctured My Fuel Tank #26
Yup, that is a tree.
Send that pic to Deere and ask them why they don't build those tractors so you can just run over things like that. They should know how we need to use them in the 'real' world. /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Glad to see you found a proper place for that bad thing. /forums/images/graemlins/wink.gif
And the fix looks real good. Hope all will be well with it.
Update:
It has been nearly a month and my $5.00 fuel tank repair is still holding. Been running the tractor harder than ever too. Beats a new $600.00 tank.....so far... /forums/images/graemlins/grin.gif
   / Punctured My Fuel Tank #29
This is amazing - I had the exact same incident with my 5105, extept instead of puncturing fuel tank, I knocked off the fuel sensing unit - cost me around 400 total to replace everything.
BUT DO I HAVE SOME GOOD NEWS FOR YOU!
I custom made an armored plate that mounts under my 5105 - it was already drilled/tapped for the mounting bolts. Every now and then I can hear a "bong" where something strikes the place and I KNOW I just saved a couple of large bills....
If you want to call me I can probably send you some pics of my plate, and I'll help in any way. No one makes one youc an buy, you have to build it yourself. I just PMd you with my telephone number. Do you think there would be a commercial need for these plates?
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2011 Doonan 482FBCHTTDBZ 53ft 40 Ton T/A Flatbed Equipment Trailer (A52377)
2011 Doonan...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
