Purchased 2305
   / Purchased 2305
Jason L's dealer now told my dealer they don't have the extra bracket set. Both are typical dealers (confused, poor phone comunication, parts doesn't know what sales is doing, hang ups when transferring phone from one dept. to another, no return of promised phone calls)
My dealer called Woods back and confirmed part number for 2305 kit. Still no release date. Part number is not in their system yet.
I hope my dealer stays on top of this. I'm afraid if they don't keep checking on it, the brackets will all be sold out and back ordered before I get mine. They still cannot just place an order since Woods doesn't have the brackets in their system yet.
   / Purchased 2305 #63
rvtech
Yes, I received my 2305 yesterday. The Disc Harrow is back ordered and should be here next week. I will spend a few hours tomorrow box blading the wash and see if it performs as I expect it to. I'm will have to extend my shop about 3 feet in order to get it to fit with the implements attached. Currently it gets top billing in the garage.
I checked out the positioning on the radiator, and I agree with you that it wiggles around too much. I do see that if the hood is adjusted incorrectly that it could move it back into the fan.
   / Purchased 2305
After my radiator hit, I adjusted the latch. I was having some trouble latching the hood prior to the damage. I would have to push on the hood and wiggle it sideways to make it latch. After I adjusted it the hood latched just by dropping it from a couple of inches like a car hood. When my dealer replaced the radiator, they readjusted the hood. Now it is like it was before (hard to latch)
I'm glad to hear you received the new 2305. I'm curious to know how the box blade works. What size and brand did you get? I have some very rough places in my field. Mostly rutted from the previous owner. I have filled some areas in with dirt, sand and light gravel from my Quanset hut floor I'm preparing for concrete. The field is still very rough and needs graded somehow. I have no experience with this and was wondering if a box blade will work or if I need a rotary tiller, or both.
   / Purchased 2305 #65
rvtech:
I purchased the Frontier BB2048. I chose it over the weight box. I couldn't see having something for ballast that didn't have any other purpose. The BB weighs about 400 pounds and make a good ballast for the FEL. It works well for what I need it for. I clean out and smooth a natural wash that fills with sand and debris during heavy rains. I would assume the scarifers would do what you needed, but that I guess would depend on how hard the ground is that you need to level as to whether you would need both.
The hood should not be difficult to close. It may be adjusted wrong. I have included the bulletin that was sent to me by my dealer on the adjustments and measurements needed to set the hood correctly.
Complaint or Symptom:
Engine Fan to Coolant Radiator Interference
Problem or Situation:
Solution:
Clearance Inspections and Potential Adjustments
2305 Advantage Series Compact Utility Tractors with an Invoice Date prior to
21 September 2005
____________________________________
There is the possibility to have engine fan to coolant radiator interference
which will result in radiator damage. Follow the checks and procedures below
to insure proper clearance between the engine fan and radiator.
1. Engine Fan and Radiator Clearance
The engine fan to radiator shroud clearance should be 10-15 mm, it is
imperative that the proper clearance is maintained. Rotate the fan blade to
the twelve o' clock position. Measure the distance between the fan blade and
the inside surface of the shroud closest to the fan blade (See PDF Link at
bottom for photos). If there is less than 10 mm clearance, then the side
support braces should be loosened and the radiator adjusted to get this
clearance. The retaining hardware should then be tightened, starting with
the upper right hand, then lower left hand, then upper left hand and then
lower right hand (See PDF Link at bottom for photos).
2. Battery Position
Verify that the battery is seated fully rearward against the two stop tabs
to insure that the front latch rod has free motion. If it is not, adjust the
battery accordingly.
3. Hood Latch Position
Insure that the wire latch hoop on the hood is striking the retainer latch
in the correct position. Verify that the lower panel assembly is installed
correctly and that the locating pins are correctly in place. If lower cowl
is properly installed, lower the hood toward the latch and visually note the
position of the upper wire latch hoop relative to the lower retainer latch.
The wire latch hoop should contact the rear of the lower retainer latch
surface at least 3 - 5 mm down the surface of the latch. This will insure
that the latch will consistently capture the hood's wire hoop (See PDF Link
at bottom for graphics).
With improper hood hoop latch strike, the radiator can be forced into the
fan during hood closure. This occurs when the hood hoop contacts the latch
on the front side (See PDF Link at bottom for photo). If the hood is open
and the unit is running, closing the hood with the latch in the position
shown will result in fan blade to radiator contact. The results will be a
punctured radiator.
If the hood's wire hoop contacts the latch surface at the top of the latch
surface, or comes to the front of the lower retainer latch, then the wire
hoop should be adjusted rearward until it comes into the proper alignment.
This can be done by inserting a lever through the wire hoop and, using
moderate pressure, bend the hoop rearward until the proper positioning is
achieved (See PDF Link at bottom for photo).
After the hoop has been adjusted, check to insure that the hoop is striking
the latch at the proper position. If adjusted correctly, shut the hood with
a firm closing motion on the hood front nose area (See PDF Link at bottom
for photo). Slamming the hood is not necessary
   / Purchased 2305
Received an email from Woods yesterday. The BH6000 brackets for the 2305 are now available. They can be oredered by any authorized dealer. The email said the brackets will be shipped in approximately 4 weeks.
   / Purchased 2305 #67
Are they sending a set directly to you? I would hope they would do that. Is this better than the last guess. I think you had mentioned 12 weeks. 4 weeks is much better than that, but I don't remember how long it has been. Let us know how the BH works with the 2305.
   / Purchased 2305
One of the owners from my dealer called. He asked about the email from Woods so I forwarded it. He emailed me back layer saying he talked with Woods. They also told him the bracket kits are in production and will be available in a few weeks. He then asked about what was different from the 2210 kit. They faxed over a parts breakdown. He said it shows only 4 different parts. 2 are mounting brackets to the CX200 loader and 2 are the sideplates going from rear to front. He then asked if they could send out the 4 different parts so we could get this backhoe mounted. Woods told him they don't release individual parts until after the kits are done. My dealer said he is going to keep working on this until we get the brackets.
I may go ahead and install everything except the brackets that don't fit so it will be ready when the rest arrive.
   / Purchased 2305
Woods now has the 2305 installation manual online. I looked through it and the 2210 installation manual. It looks like there are a few more differences than I was told. The seat has a new swivel instead of a seperate seat and bracket. There is also a bracket to change position of the smv sign. There are also the obvious differences between the two tractors.
I'm going to wait for the correct kit before I start installation.
   / Purchased 2305
Release date for Woods BH6000 attachment bracket to 2305 is November 24th
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A53426)
2020 CHEVROLET...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A53426)
2024 TIMPTE HOPPER...
2006 Peterbilt 379 Tri-Axle Day Cab Truck Tractor (A51692)
2006 Peterbilt 379...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
