Push with 3 point?
   / Push with 3 point? #41
Didn't use the backblade this year (needed the ballast box weight for traction more then the blade).
If the accumulation is more then 6"-8" (depends on if the snow is dry and fluffy or wet and heavy), I prefer to drive forward for the first passes. It's easier on the tractor. The blade will be a 1/2" or so off the surface.
After that, it's a combination of pushing in reverse (pushing the piles back further) and some final scraping (going forward).
RalphVA does have a point about the tires compressing the snow, but that's something I can live with.
   / Push with 3 point? #42
Very informative. Thanks for the simple question that became a helpful thread. I push snow and other stuff in reverse with box and regular blades all the time, but I always go slow. Good tips!
   / Push with 3 point? #43
I bent one of my lower bars pretty bad pushing a grader blade. Neighbor did same to both of his on a small Kubota.
I'd be willing to bet those smaller units used arms with a bend to get the width needed for big implements? My TZ25 was horrible in this aspect when pushing a box blade. They would bend at the lift pivot holes, the weak point. I got really good at removing them and using a press to straighten them back out. I had intended on making a "T" cross section of them by welding on some 1/2x1 flat stock on the bottoms, but fixed the problem the right way instead..... Bought a bigger tractor!
   / Push with 3 point? #44
I have repaired my boxblade, damaged when backing up into a pile a dirt. It probably won't ever break again, since I decided to over-do it in the repair end. I extended the front arms a little (about six inches) in order to get more height when trying to smooth a pile of dirt. Top link isn't quite long enough for heavy angles, but works fine in "normal mode". The next post I make about tearing up something while backing, will probably be my lift arms, since the original boxblade used 1/2 x 3 inch flat bar for the front arms. I added a piece to it, bolted and welded next to it, full length, of 1.125 x 3 inch. Quite a bit of overkill, but I didn't have a piece of flatbar in the 3/4 I wanted to use, so I made some flatbar out of a piece of leftover plate by slicing off a couple of pieces. Took a while on my Bridgeport, but I had all day, since the wife is gone to a meeting in North Georgia. Time well spent, having fun in the shop instead of running the streets.
David from jax
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
KLEEMAN MS192 MOBILE SCREEN (A51242)
KLEEMAN MS192...
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
DEWALT ROTARY HAMMER (A50854)
DEWALT ROTARY...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
