Pushing T-posts in with FEL?
   / Pushing T-posts in with FEL? #11
I don't drive many posts but tools draw my attention in case I may want to use one. This air operated driver fascinated me so I did the internet searches for air driven post drivers. Rhino has one for around $4000.00, yep $4000.00 where this one above is $450 but then I found one at Northern Tool (it's on ebay but sure it can be bought from Northern Tool direct) for under $400. No, I'm not buying......now:) but if I were/do then I'd go for this one no more than I'd use it.
Striker Air-Operated Post Driver - 2 CFM 80-100 PSI New - eBay (item 280712114260 end time Aug-18-11 12:06:09 PDT)
Hey John... I'm gonna be down your way on Saturday. Getting a tiller from Barlows unless something changes this week.
Ian
   / Pushing T-posts in with FEL? #13
Ian
I'll trade you 4 18" tires on Chrome rims (listed on Lexington Craigs list) for your cultivator. Bring it with you and pick up the tires.:):thumbsup:
   / Pushing T-posts in with FEL? #14
It's storming to beat the band right now and the runoff generally goes through the area where I want the posts, maybe the ground will be softer tomorrow. I'll get a scoop of gravel in the bucket and see how it does. I'll probably end up taking a handful of ibuprofen and using the shoulder wrecker instead.
Ian
Try the load first. You may be surprised.
   / Pushing T-posts in with FEL? #15
Depends what they're made of and what you are driving them into.
Steel ? Yes, if into fairly rock free soil.
F/glass ? No.
Broke it yesterday. Only thing I could find in a 2" wide square U bolt when I built it was 1/4". They couldn't quite take the strain. I'll have to go with backer plates and regular bolts when I get around to fixing it.
Ian
2012 Tiger 130BBL Vacuum Trailer (A50860)
2012 Tiger 130BBL...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
UNUSED 20PCS 2in. Polyester Lifting Strap (A50860)
UNUSED 20PCS 2in...
2015 Ford F-650 20ft. Flatbed Truck (A48081)
2015 Ford F-650...
