Putting Water Hydrants In
   / Putting Water Hydrants In
After that I leveled and backfilled and it was time for a couple inspections. /forums/images/graemlins/smile.gif
Here are the inspectors /forums/images/graemlins/smile.gif
And Sully and I standing by the finished northern hydrant.
Just to give you an idea of how long these puppies are. Here is the South hydrant before installation.
Here is a shot of the pit for the South hydrant. You can see a concrete block in the bottom. This serves as a seat for the hydrant to alleviate stress from down pressures caused when the water is releasted from the valve.
That's a 6 ft ladder for reference.
here I am making final adjustments and backfilling with pea gravel.
And finally the finished South hydrant. I still have to do some work to connect the lines to the main water source later. I am having some other excavation done near the water entrance to the house to repair my geothermal leak, and I will connect them at that time. That'll be in 2-3 weeks so I'll post the updates then. Thanks for watching!
   / Putting Water Hydrants In #47
Great project Tim /forums/images/graemlins/cool.gif
   / Putting Water Hydrants In #48
<font color="blue"> The water line will need to go under my septic line </font>
My parents shared a well with a neighbor, they, the neighbors and my parents started having intestinal problems, i.e. getting sick etc. They got the water tested and it had a high level of fecal bacteria in it. It seems the neighbor installed a leaky septic line over the water line and it was contaminating the fresh water somehow. The county made them move their septic line so it was under the fresh water line, turns out it was contrary to code. I wouldn't have thought there was anyway for it to leak into the water pipe but somebody said something about capillary (sp?) action.
cqaigy,
thanks for the concern with this. I considered this but I really didn't have a choice in this instance, and the line is out to my livestock and will not be drinking water for humans. Having said that the lines are not leaky and the soils involved did not have any unusual odors or discolorations. Also there will be approximatedly 5ft between the two. The water line will not have any joints nearby the crossing, and as far as a capilary action I can't see them letting people run potable water through this pipe if it wasn't rated to keep the inside material safe. In addition to that the primary ground material is hard clay which they use for retaining leachate in many instances, so it will form a natural barrier of sorts between the two.
One of my other thoughts on this is that this must happen in cities all the time with services crossing. When you need to get from point a to point b, there's really no way around it.
Skid Of Metal T Posts (A50775)
Skid Of Metal T...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2018 DRAGON 150...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A56129)
2012 FREIGHTLINER...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2006 KENWORTH (INOPERABLE)T800 (A55745)
2006 KENWORTH...
