DaveK OR
OK, I'm guessing there is an easy answer to this, but I haven't figured it out for myself. I'm connecting my backhoe hydraulics to the tractor through quick-connect fittings. Residual pressure in the system is preventing the poppets in the quick-connects from opening as I press the fittings together, and it keeps them from seating properly. I can manage the tractor-side fittings, simply by flipping the control valve to make the port a "return" line. The backhoe side doesn't have any similar capability that I've found, and I need to relieve pressure on both sides of the connection.
Any suggestions, other than a modified c-clamp to force the poppet to release, resulting in a squirt of hydraulic oil when it opens? Trying to do it force the connections together by hand is really difficult, unless there's a simple trick I don't know.
