Question Cleaning Yanmar Injection Pump
/ Question Cleaning Yanmar Injection Pump #1
ohiogar
John Deere 4300
Hello,
I need help...at least knowledgeable opinions.
I bought a John Deere 4400 tractor that had sat for many years without sheet metal. It was pretty much
sealed up BUT
They left the inlet and bypass hose bibs of the injector pump open with the nipples pointed up. From what I can see through the ports there is a lot of nasty rust and corrosion.
MY THOUGHT:
Mix either muriatic acid or Phosphoric acid with Diesel fuel and circulate that through the system via electric fuel pump until it cleans the residue.
ANY comments will be appreciated.
OR other ways to clean it.
NOTE: There is no way that I can see to clean this chamber even if the pump were removed and totally disassembled.
Regards Gary
/ Question Cleaning Yanmar Injection Pump #2
Do yourself a favor and send the pump out to be rebuilt.......:2cents:
Well here is the deal I think the motor is low hours and should be fine BUT
if it is junk I would have the cost of the pump repair.
How much does it cost to have the pump gone through? roughly
/ Question Cleaning Yanmar Injection Pump #4
Idk I guess it depends on how many parts are changed if you can see rust/corrosion it might be real bad inside...
I think it is just the diesel fuel chamber between the nipples that has corrosion.
all else looks really good.
/ Question Cleaning Yanmar Injection Pump #6
Any rust left in the pump will ruin the seals and injectors. Then you will spend more money . Why was it apart in the first place?
The tractor was bought from a Georgia technical school that trained JD mechanics. The program ended and the tractor
was just pushed out back. They had 3 4400's so this one ended up being the parts machine.
The inlet and bypass chamber on the pump for the diesel fuel is the only bad thing on this chassis. I think it is a low hour machine.
/ Question Cleaning Yanmar Injection Pump #8
Nice find.. You can call around and see how much for a rebuilt pump or to rebuild yours. Or try to flush it out first then go from there..
That's what I was thinking ...Use a weak solution and maybe I won't hurt much.
The acid will not hurt rubber. If diesel fuel and acid are compatible I don't see much downside.
/ Question Cleaning Yanmar Injection Pump #10
Good luck.....:)
/ Question Cleaning Yanmar Injection Pump #11
Or upside.
Forcing rust particles into the delivery valves and barrels of the injection pump is a bad idea.
Price a new pump and get a worst case estimate on professionally repairing that one.
The probability of you doing more harm than good are very high.
/ Question Cleaning Yanmar Injection Pump #12
Send a PM to member "thepumpguysc" for some guidance. Seems he is also quite knowledgeable on injection pumps. Or just go read up on some of his posts.
But your plan to try to clean it with some solution doesn't sound like a good one.
Good luck..
/ Question Cleaning Yanmar Injection Pump #13
Good luck..
Agreed!
Follow the advice of RickB !
You are very likely to cause even worse problems with your flush scheme.
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2018 CATERPILLAR D6K2 XL CRAWLER DOZER (A60429)
2018 CATERPILLAR...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- DEMO UNIT (A61306)
Greenworks...
iDrive TDS-2010H...
