Question Cleaning Yanmar Injection Pump
   / Question Cleaning Yanmar Injection Pump #11
That's what I was thinking ...Use a weak solution and maybe I won't hurt much.
The acid will not hurt rubber. If diesel fuel and acid are compatible I don't see much downside.
Or upside.
Forcing rust particles into the delivery valves and barrels of the injection pump is a bad idea.
Price a new pump and get a worst case estimate on professionally repairing that one.
The probability of you doing more harm than good are very high.
   / Question Cleaning Yanmar Injection Pump #12
Send a PM to member "thepumpguysc" for some guidance. Seems he is also quite knowledgeable on injection pumps. Or just go read up on some of his posts.
But your plan to try to clean it with some solution doesn't sound like a good one.
Good luck..
   / Question Cleaning Yanmar Injection Pump #13
Good luck..
Agreed!
Follow the advice of RickB !
You are very likely to cause even worse problems with your flush scheme.
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54313)
2019 KENWORTH T680...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
2011 Kenworth T800 Water Truck (A54865)
2011 Kenworth T800...
KIDS DIRT BIKE (A55758)
KIDS DIRT BIKE...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
