Quick and easy window screen
/ Quick and easy window screen #11
Rox,
I built a screan porch a while back. Most folks staple the screan to the posts and cover the mess with a strip of wood. This would not work for you. I wanted to be able to have screans in the summer and glass in the winter. So I built frames. The trick to a good screan frame is to have the screan very taught/tight. Otherwise, you have a distorted view. Metal fram screans used on standard windows use a 1/8" groove around the frame. A rubber rope is "rolled" in the groove to hold the screan. As you put the last rope in it gets very tight. So back to my frames; I made them of wood but cut this grove on my table saw. Worked like a charm.
I travel to Europe quite often and I have noticed that they do not use AC or Screans. If you leave your windows open, you will likely find a pigion sitting on your bed!
/ Quick and easy window screen #12
Rox I sure wish I lived nearby so that I could come over to your farm taste & buy some olive oil. Not to offend some of my italian friends, but some of the best olive oil I've ever tasted was in France and I brought several types home with me.
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2019 Kubota SVL75-2 (A60462)
2019 Kubota...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
