Quick Attachment system
/ Quick Attachment system #1
1kubota
powell, tn
kubota b7200
Hi everyone,
I have received my quick attach system and I didn't receive any directions on how to install them. I received 6 big washers that have a fold in them (when I get home today I will post pictures) Can someone please explain what the washers are for thanks.
Well I called titain and asked what washers were for, thay asked me what washers it wasn't supposed to have any washers with them.
/ Quick Attachment system #3
Interesting. Please post some pictures. Thank you.
/ Quick Attachment system #4
The washers with the fold are for the pins on your attachments. You put them on the lift pin, then attach the snap pin through the hole in the fold of the washer (they should have a hole anyway), and this helps with stability of the qa.
/ Quick Attachment system #5
I didn't think Titan sold 3 pth quick adaptors only quick hitch for loaders?
/ Quick Attachment system #6
Here is how they go on the bend and the clip hold them at the outer ends so the 'fingers' of the hitch can grab in between
Harbor Freight Quick Hitch Item# 97214 (part III quick hitching to attachment or implement) - YouTube
Harbor Freight Quick Hitch Item# 97214 (part I unboxing) - YouTube
Quick Hitch Modification - YouTube
/ Quick Attachment system #7
Excellent picture, chopped. Very clear how it is used.
/ Quick Attachment system #8
If you ned more other than buying them there is a thread here somewhere on how to make them. basically large washer bent and then drill a hole for the clip to pass through. Not sure if its much of a savings from just buying them.
/ Quick Attachment system #9
Yes, but it is more fun to make them and you have a feeling of accomplishment! I have made several
That would work out when I finish up with my backhoe I'll have to try it thanks for the info.
2016 Dodge 5500 Box Truck (A63116)
2016 Dodge 5500...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
John Deere 5115M Tractor (A64047)
John Deere 5115M...
