Quick Connect Couplers Question…
   / Quick Connect Couplers Question… #1
mustangmarty1967
New Holland TN75
How do you disconnect the hydraulic Quick Connectors on the back of a New Holland TN75? I don’t see a kind of a collar that slides back. They say Pioneer on them.
   / Quick Connect Couplers Question… #2
Post a photo. I gave my own quick connect issue. I have a 14 yo flat face connector that i cannot separate. Never seen anything like it
   / Quick Connect Couplers Question… #3
How do you disconnect the hydraulic Quick Connectors on the back of a TN75? I don’t see a kind of a collar that slides back. They say Pioneer on them.
Probably, just pull firmly while the connector is not under hydraulic pressure.
   / Quick Connect Couplers Question… #4
Try pushing in and then pulling out all in one quick motion. This is typical of breakaway couplers.
   / Quick Connect Couplers Question… #5
On my excavator's flat face connectors, I have to rotate the collar until it lines up with a tiny pin, which then allows the collar to retract/ release. And I usually do that with the machine off and pressure relieved.
Good luck.
   / Quick Connect Couplers Question… #6
Put the remote feeding the attachment hoses in “float” (make sure there’s no people/pets under the attachment FIRST). The hoses will pull right out.
   / Quick Connect Couplers Question… #7
Good luck.
Ya, ive been removing these for 14 years. The cover slides all the way back, but the male end wiggles but doesnt pull out. Even with prying
   / Quick Connect Couplers Question… #8
What's the temp? I've had water get in and freeze which will keep them from releasing.
Sent from my SM-S921U using TractorByNet mobile app
   / Quick Connect Couplers Question… #10
OMG….. just choosing the correct flat faced coupler sucks. I ordered one set on amazon. Showed proper inlet thread size and everything. Got them the next day.
Thread pitch is wrong. Stupid amazon.
Heading into town to Parker store to get correct set. It will cost more, but at least they will fit.
UNUSED JCT 72" HYD BRUSH CUTTER (A58376)
UNUSED JCT 72" HYD...
New/Unused Fuel Pump with 50ft of Hose (A57453)
New/Unused Fuel...
Takeuchi TB216 (A57148)
Takeuchi TB216...
3ft Teakwood Cowboy (A57454)
3ft Teakwood...
72in Boom Lift Basket (A56857)
72in Boom Lift...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
