Quick Hitch disappointment
   / Quick Hitch disappointment #41
makes hooking up the top link on the Pat's system look even better!
   / Quick Hitch disappointment #42
so when you do your worst case scenarios, there's a labor number. Hmmm. About the same as that fancy new adapter.
Not if you can weld...and I needed a good reason to start.
If you were to ask me (and I realize no one did) everyone that owns a tractor should also own and know how to use a welder. They are not that expensive, and it ain't that hard to learn.
well assume I did ask you Jim and yes I sure agree with you. It's why a nice new welder has been in my garage for a year. Bought it and then my arm went bad. Well that's fixed now, luckily not with a welder...:D
   / Quick Hitch disappointment #44
Maybe we can weld up an exoskeleton for that bum arm:D
I sure hope not...but i have about four different kinds of pads and protectors for it. I squashed my ulnar nerve (on the desks over forty years?)
and now I have to protect it. but a little foam will do. We'll save the sparky stuff for later.
   / Quick Hitch disappointment #46
You are disappointed with the quick hitch because the implements are not built to industry standard specifications?
Sounds backwards to me.
Bruce
   / Quick Hitch disappointment #47
Bruce
Completely agree!!
I would agree, except for the players. Land Pride and Kubota. Ok, no squawk at Land Pride, Kubota built apparently too skinny a ballast box and that's where
the hairy eyeball should be focused. But since they advertise their union, and have for at least three years I believe, I sure had expected more.
And boy would I have not spent more than twice as much on the quick hitch. Since the reality is each implement has to be tested and modified.
I'd be curious to compare the design of the Land Pride against the JD I-Match. Being delivered next Monday, will test it next week. When I'm done moving about fifteen shrubs, off comes the ballast box and on goes my 8 foot Land Pride mower. It had better slide into that same company device slicker than goose poop.
   / Quick Hitch disappointment #49
I bought the CAT 2 quick hitch from Tractor Supply and found that the only implement that it fits is Bush Hog 3 point cutter even though the Hay King Pasture renovator and other items are supposed to be "QH Compatible". The clevis ears on the renovator were about 1/2" too narrow for the QH. Everything else was off even more. Took the QH back to TSC.
Have a set of the CAT 1 Delta Hook on Kubota B2710 with receiver plates on box blade, rotary cutter, disc. I can hook up or drop them in a few seconds. Add about 30 seconds to hook up PTO on cutter. Having the hydraulic upper link from Fit-Rite makes it even easier and faster.
I am seriously considering biting the $$$$ bullet and buying a set of CAT 2 Delta Hook plates. The Delta Hook receiver plates have significant adjustment for varying width lower pins or clevis'.
   / Quick Hitch disappointment #50
What have you been up to Jack???? Haven't heard much out of you for a while. Hope things are well over there. We sent the First Lady over to entertain you folks. You can keep her if you like.... ;)
hahahahaha, I m busy in my business, USA First Lady come here entertain those big VIP of government, not me, doesn't Abama feel lonely without her???
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 TRUCK (A51406)
2011 INTERNATIONAL...
2014 Jacobsen AR3 Commercial Mower (A53421)
2014 Jacobsen AR3...
12in x 16.5in Kubota RTV-X1140 Tires (A52377)
12in x 16.5in...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
