quick hitch pin adapters were to buy?
   / quick hitch pin adapters were to buy? #11
brucewj
What are the inside and outside diameters? (excluding the large end)
   / quick hitch pin adapters were to buy? #12
ID is 0.87 (7/8) and th OD is 1.44 (1 7/16).
The throat on my quick hitch is 1.127 (1 1/8). My conversions from decimals may be a little off but that's as close as my feable mind can go.
I am really getting frustrated because I can't seem to find a set that fits my quick hitch, and every place I ask about them no one knows what they are and always tell me to just use a cat1 to cat 2 bushing and clip pins.
I have the busings and clip pins now.
   / quick hitch pin adapters were to buy? #13
I am going to try again. Countrybumpkin supplied a link and I checked for one that has the dimensions I need I found it as follows:
QUICK HITCH ADAPTER KIT CAT 1-2
I hope this one works.
   / quick hitch pin adapters were to buy? #14
Which quickhitch do you have?
Mine (JD iMatch) which I thought was to a standard, is the 1 1/2".
So my adapters are either cat II to cat III with a bushing inside, or cat I to cat III.
   / quick hitch pin adapters were to buy? #15
I use bushings that slide over the cat. 1 pins. They are like a ring that slides over the links and are quite cheap from Speeco.
   / quick hitch pin adapters were to buy? #16
Well I picked up my harbor freight quick hitch a couple of weeks ago...
image.php
Which quick hitch do you have?
Like the OP, I got my quick hitch at Harbor Freight. I saw where the Imatch is a cat 3, but I need bushings that go from Cat 1 to cat 2. Apparently not everything meets the standard. I wish I would have checked the dimensions before ordering. Maybe my experience can be of benefit to others.
   / quick hitch pin adapters were to buy? #17
You have everything you need, while nice, those $26 ones are over kill. There may be just a bit of slop but not enough to matter.
   / quick hitch pin adapters were to buy? #18
I'm waiting for my order to come in from Ag supply, I too have a Harbor freight hitch and the hitch pin openings measured 1 1/2" wonder why your hitch was smaller? I ordered 4 sets of the cat 1 to cat 3 adapters for what I could purchase two sets of the Cat 2 to cat 3 adapters local. Plus I would still have to use a bushing or change the hitch pins on my equipment to fit the Cat 2 adapters.
   / quick hitch pin adapters were to buy? #20
I received my adapters the other day and have to say they are real well made and work great for my implements.
2012 Ford Expedition XLT 4x4 SUV (A50324)
2012 Ford...
Toro Z Master 2000 Zero Turn Commercial Mower (A50322)
Toro Z Master 2000...
2022 John Deere 6135E (A50120)
2022 John Deere...
Dion 1224 XC Silage Chopper (A50515)
Dion 1224 XC...
