R4 tire wear?
   / R4 tire wear? #1
dirtworksequip
Wheeling, WV
2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
What kind of hours is anyone getting out of their R4 tires. Fronts & rears?
   / R4 tire wear? #2
500+ hours in 8 years and the fronts are 50%+. My tractor sees very little road time, maybe 20 miles/yr.
   / R4 tire wear?
Thanks for your reply. I was just curious of what kind of hours to expect out of R4's. My old 870 had R1's with 1950 hours on the original rears and I had replaced fronts twice.
   / R4 tire wear? #4
910 hours on my R-4's .
I have around 50% fronts and 75% rears
   / R4 tire wear? #5
Almost no wear on my rears in 400+ hours. But then again, I have chains on year round for traction in the mud.
Fronts are 90%
Titan's on the front and Firestones on the rear
j
   / R4 tire wear? #6
I have turf tires on the rear, but have R4 on front.
I originally had turf in front but they did not hold up well with bucket work so I put R4 on the front (they are the same size as the original turf). I get about 800 hr. before I replace them. I have 4700 hours on my NH 1620. I am always in 4 wheel drive and on and off hard surfaces. I still have my original turf tires in back, but the side walls are showing weather checking tread is still 50% or better.
   / R4 tire wear? #7
Over 800 hr on rear and real good yet and replaced the front once at about 450 on my L48 but do a lot of heavy loader work on the blacktop.
   / R4 tire wear? #8
Almost 800 hours on my B2910 - the rears are hardly worn at all and the fronts are at probably at only 30% left. I've had slow leaks in the front so they are occassionally under-inflated and probably have driven it on pavement a few times in 4WD, which may have contributed to the high wear.
   / R4 tire wear? #9
I'm at almost 700 hours on my NH TC24. Rears I would guess are probably 80 - 90% left. Fronts are probably 60 - 70% left. Most of the time in grass in 2wd unless doing loader work or something. I'm only on pavement 2 or 3 times of the year when I have to go to the "other side" of our property so I can rough cut it.
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
2012 KENWORTH T660 ROAD TRACTOR (A52706)
2012 KENWORTH T660...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
Miles read : 112,969 (A50323)
Miles read ...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
