Radiator HELP!!!
   / Radiator HELP!!! #11
I would think as thin (well ok it's not real thick) as the metal is that holds the bolts to the radiator (if you aren't worried about the radiator) just drive a wedge between the bottom of the radiator and the bracket and bend the heck out of it, you might be able to bend the metal that holds the carriage bolts enough to get it to slide it side ways to take it off. In theory (for the record I just replaced mine, the guy I got it from had a massey radiator with no shroud on it) the think might have the rubber washers (hard by now I'm sure) that you might be able to get them to break up and then slide the thing side ways. the dremel with a cutting wheel is not a bad idea either
   / Radiator HELP!!!
I ground the bolts off and replaced it... the shroud doesn't fit but oh well... Thanks though
THREE POINT ATTACHMENT (A58214)
THREE POINT...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
