Radio Install in Kubota RTV1100
   / Radio Install in Kubota RTV1100 #21
Thanks Steve. My problem was I didn't realize that the sleeve came as part of the DIN radio - tells you how long it's been since I messed with any car audio stuff:eek:
   / Radio Install in Kubota RTV1100 #22
Steve did you use the aluminum bracket that Kubota ships loose or just mount it in the face cover plate
   / Radio Install in Kubota RTV1100 #23
Yep - used the bracket after I found it (the dealer had put it in the toolbox mounted on the left side of the tractor). Still a little shaky when on rough ground - probably need to decrease my ground speed :eek:
   / Radio Install in Kubota RTV1100 #24
Not a big deal as long as you have access to a pig tail for the factory harness...The shortness of the harness is just plain torture for hard wiring, Kubota couldn't add 3" of wire?...I see that someone came out with an aftermarket pigtail...Figures that showed up after the grief I went through wiring a Kenwood to mine. Why are the factory speakers so bad?
The factory speakers are so " cheap " because they wanted to keep the price down to only twenty grand for the unit. I bought mine installed. Guess I am just terrible with electronics. Even if I wired it correctly it would vibrate out of the dash at some point. Speaker replacement is a " someday " project.
   / Radio Install in Kubota RTV1100 #25
My speakers are a someday project that has yet to come after 2 years...Pretty sad they had to install paper cones to keep the price at 20 large..Guess I should be happy something is installed.
Gents,
Any speaker you put in this location is not going to sound good while operating the RTV, there is just not enough room up there to get the airspace required to reproduce any kind on lower frequencies, the Infinity co-axles I installed in mine sound great while parked but as soon as you start the RTV the noise drowns out all but the higher frequencies making and speaker sound like a tin can.
I have some small woofers from my old car audio collection that I will be installing sometime to eliminate the problem, I'm going to construct a small center console with cup holders, storage, etc. and will incorporate the woofers in it.
   / Radio Install in Kubota RTV1100 #27
Might be easier to hook up speakers on my cell phone Guess all We need now is some snow
   / Radio Install in Kubota RTV1100 #28
Thank you for this we were having difficulty locating the 9 pin harness!
   / Radio Install in Kubota RTV1100 #29
How do i install a radio in my 2015 RTV-1100 cab. They said it is all pre-wired and ready to put in but I don't know where or how.
   / Radio Install in Kubota RTV1100 #30
I have the 2014 RTV-X1100C and installed my radio. Just remove the plastic cover/plate on overhead console and all the wires are already there.
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
2023 John Deere 333G for Parts (A55315)
2023 John Deere...
Reading Classic I I (A57880)
Reading Classic I...
Push Mower (A55973)
Push Mower (A55973)
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
