Raising a barn
   / Raising a barn
It's been awhile since posting any progress but I finally got around to adding some lights over the work bench. (LED)
I wanted to see how bright they were before putting them throughout the barn. Here's a shot at night. I do like how bright they are. :thumbsup:
   / Raising a barn #124
Costco now has LED shoplight for $10. Bought mine when they were $30 or more... These now interconnect.
   / Raising a barn
I will have to do some shopping around. I need at least 10 lights to finish the main barn area. Quite a difference in price/dollars.
   / Raising a barn #126
Sorry for the wording. They sure do let in a lot of light. Where did you source/purchase the translucent panels?
Up here in Ohio, Menards carries the clear plastic panels along with all the other metal and trims you need for a pole barn project. Not sure if you have them in your area though.
HI Cat, great thread and nice project. I love how you spaced your double trusses a little further out (around me in Ohio the norm is 4' or 8'), and I like how you stood the 2x6 purlins vertical. A lot more strength over the span. How did you attach them to the truss though? I couldn't tell if you used Simpson type straps or if they were toe nailed.
   / Raising a barn
Thanks Lance,
Look at post #14 second picture. Those small upright boards are nailed between the trusses, then the purlins are nailed to the uprights. It's a very simple design and easy for the novice builder (like me) to build.
   / Raising a barn
Thought I would update this thread now that I am nearly done with everything I plan to do with the barn. Still have not completed the lighting, but I don't use it much in the dark so no hurry.
All these pictures were taken today. Basically just showing each corner, cement is all the way around the perimeter with "crusher fines" as the main floor. I really like the stuff, it packs hard and is not dusty.:thumbsup:
As you can see there is a small sliver of light on the left side. (direct sunlight) Other than that there was no artificial light. Point is look how bright it is inside, both the big doors are shut. So if any of you are building and not sure about translucent panels---here's the proof. I could work in there even on a cloudy day and see fine without lights.
Added a picture of my fence charger. Keeps the animals where they belong.:)
And the last is how it's looks today. Sure wish it would warm up some so the hay would start growing more. But it is coming along great.
   / Raising a barn #130
I have a southerner question. Is it better to help melt the snow off the roof to leave it uninsulated? That way, the snow load doesn't get too big?
   / Raising a barn
Thanks japody, it was a lot of work, but well worth the effort.:thumbsup:
Kyle,
Not really sure, I know in the dead of winter the snow slides off usually while it's snowing or within a day even when it's single digit cold. There are times the snow sticks on the awning roof for a few days but only towards the middle of the barn, the ends always slide off. Not sure why. The south end of the barn does get warmer because the sun hitting the metal and heating it up. That is one of the reasons I went with darker colors. I figured I could open the doors in the summer and cool the barn down if I need to work in there. It works good since the barn has north/south doors and that's usually where the wind comes from.
   / Raising a barn
It really turned out nice. I like all the room.
I am very pleased with it. I know whenever I take someone in there for the first time, the first word out of their mouth is "wow". Everytime.
If I had to do it over I would have built it 8' longer with the post on 10' centers. Only because it would have worked out better with the fencing.
   / Raising a barn #134
Outstanding!!! You've created an amazing space that seems to be the perfect size for your needs. The only criticism that I have is that you need to mount those elk antlers on the wall somewhere better then sitting on that cabinet. :):laughing::drink:
   / Raising a barn #135
WOW is an understatement . AWOWSOME would be more like it . I still think I could stare at that view all day , and of course get nothing done . Where are the animals , want to see them . Kevin .
   / Raising a barn
Eddie I was sitting in one of those white chairs (in the pictures) just yesterday thinking the same thing about the elk antlers.
Kevin, when I said my wife thinks she is a barn widow, I was not kidding. Sometimes I just sit and look out the south door and watch the hay grow with the radio on. I'll have to find a picture of the cows.
   / Raising a barn #137
With a view like that, I could watch the grass grow.
   / Raising a barn
Kevin, if you are out there; here's a couple calves. The one with some red is very friendly. He follows me around like a dog.
   / Raising a barn #139
Subscribing to this thread after Cat Fever popped into mine. Will read it all later today
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
