Rake Design Help Needed....
/ Rake Design Help Needed.... #1
Maine_Polack
Central Maine
Mahindra 6500 4WD
I am in need of a rake to mount on three point. With what I have in mind is using it to gather brush, and to loosen soil, if I want.
I have this heavy duty, 8" rear blade. Instead of building a whole new rig to mount a rake on, I would like to use this blade.:eek:
Con't...
I also have parts and pieces of old horse drawn "Spring tooth" harrows. Have 30 teeth in all. A couple of different sizes, but I think I can make them work for rake teeth.:eek: :eek:
[About 25 yrs. ago I used the harrow in front - pulled by a "63", 4 cyl, International Scout, door yard plow - to help level a couple of acres around my house.]
I would like to use these "spring teeth", mounted on a "beam", ( have some heavy angle iron I'm hoping to use), to fab. a removable rake that would attach to the bottom rear of the blade. See first photo.
I realize it would be heavy, that's what I want.
I would like to attach the beam - with teeth permanently mounted on it - using pins (?), or... in such a way that it is not a half hour job to mount/detach.:eek: :eek: :eek:
I am certainly "designly challanged", and have used this forum for many of the ideas it has presented.
When I think about attaching/detaching this rake, my face says :eek: !!!, and my brain turns to oatmeal.
I am looking for people with Visiion to help me solve my problem....well this one, that I'm willing to talk about anyway.
Al
/ Rake Design Help Needed.... #4
MainePolack
I rigged some spring teeth on an angle bar as you plan and it works extremely well. I find I need no weight to draw the teeth into the ground....their shape takes care of that: the harder the digging, the deeper they want to dig. Anyway, I built a multi-purpose receiver hitch for my 3PH. It has 3 - 2" x 2" receiver tubes, 1 in the centre for a trailer ball and a pair on the outsides to mount the spring tooth bar, future forks, etc., etc. Installing the spring tooth bar is easy - just pull 2 pins. insert and reinstall the pins. Perhaps you could weld 2 receiver tubes onto your blade for the quick attach setup.
Attached are photos of the receiver hitch and the harrow in action. Sorry, I don't have a closeup of the harrow.
/ Rake Design Help Needed.... #5
Looks like a fun project! One I have been thinking about for a while. If I can be of any help, please PM me… I would be happy to help you out with any welding you may need. Your spring harrow looks like one my neighbor has. If you have the spring tines, the rest should be easy.
Gary
Gary, Thanks for the offer, but I enjoy welding. Not much good at it, but haven't had a weld break yet.
I'm about an hour ride away from you. Sangerville.
"Choker of Herring"
I actually do have a couple of recievers on the blade, per attachment.
You've got me thinking that perhaps I am making this more complicated than need be. I wanted to use the blade because it angled and swiveled. Maybe I don't really need the rake to do this.
I appreciate your input, cause now I'm really cogitating on it.:D
/ Rake Design Help Needed.... #8
your mockup is almost there IMO
take some heavy gauge C cannel weld a series of 1" pins to the top 6, 8 , 12" whatever on center , drill matching holes in the rear stifening rib of the blade.
then bolt the tines on to the C.
something like
or you could go with heavy angle and bolt the font of the tines to the back of the L and weld some little reinforcemnt triangles to the inside of the L
i could be underestimateing the bending force involved but if properly braced i think it would work
the reason i say C or L is with tube you'd have no way of fishing nuts into the tube, although if it was heavy wall stuff i suppose you could tap it.
/ Rake Design Help Needed.... #10
Schmism has a good idea there, real simple to build. I would bolt the C or L to the blade rather than use pins, to avoid play in the connection.
/ Rake Design Help Needed.... #11
I was going to suggest the bolt on thing but tossed out the pin on idea for ease of putting it on and off. After all who wants to mess with a handfull of bolts.
I think I will mount it on the rear blade. I agree with both of you about bolting vs. pinning it on.
I need the rake now, however I can see that this is one of those projects that will take time. Haven't even begun to take the old stuff apart yet. Lots of holes to drill... So, unless it rains a lot, It will be an ongoing thing that will be accomplished in bits and pieces, as time allows.
I do appreciate your ideas.:)
Al
After further consideration - there are a lot of different ways to build this - I decided to mount this rake on my fork frame. I thought that going forward would be a plus.
I "borrowed" the receiver and hitch method.
I did not bolt on the teeth. I welded them on as shown.
Front view.
Well....after 10 minutes of gentle & slow usage this is what it looked like. It was to put it mildly a total bust.
I did rake a little brush. 50% of the time it would not dump off. Had to get off the tractor:( , and pull brush off. I could live with that.
Going forward 2 teeth broke in the middle, not at the weld. Tried back dragging it for about 2 seconds. The result was 3 loud "cracks":eek: . These three teeth broke off at the welds. A couple of other teeth just bent sideways.
These teeth still seemed to have the "spring" in them. But, they were made to be used with a horse or two, and I used 65.
So back to the thinkin' about it. Any thoughts/ideas?
Thanks, Al
/ Rake Design Help Needed.... #16
Perhaps continue with the idea but put the rake on the back of the tractor and add gauge wheels if you wish.
A rake for my little tractor.
I had thought of that...but the fact that the teeth broke so easily, is making me think twice. The blade that was in the original plan weight in about 1000#, which would be on top of the teeth. And, I'm hesitant about rebuilding to use on the rear by itself, because they seem so fragile.
Trying to think of something else to use. I do have a bunch of RR spikes, but they are too short, me thinks.
Herringchocker - any chance of a closed pic of your rig? Have you had any problem with the teeth breaking?
I'm thinking more of the lines of a root rake now. Quite expensive, so I enjoy home building. Going to have to find something to use as teeth. If I buy the material new, I might as well just buy the rig itself, for the price diff.
Steel is really up there.
/ Rake Design Help Needed.... #18
Looks to me like you got the angle of the "teeth" all wrong.
I was going off existing rake desings which have the teeth or fingers almost vertical when they meet the ground. This way only force they see is horzontal, which is why there is the big curve of steel in them. They bend (spring steel) allows the finger to give horzontally then go back to its org vertical postion.
(think about the fingers on a comb)
so rotate 90deg and remount see how it works... (a sorry hack job below)
/ Rake Design Help Needed.... #19
Agree with schmism on the too much angle.
Look at your rake teeth on the pull type springtooth and you will see the max angle they can handle. Make your's fit that and I doubt they will break.
My guess is those teeth are some kind of tempered to retain their spring, so welding on them messes that up. If you can use the clamps like the pull type, the teeth will last longer. Of course, if you have plenty, weld away and just replace as necessary.
Hope this helps.
ron
Well I thought that I was at about the right angle, at times anyway. One of the reasons for the front mount was that I thought being able to change the angle easily would be a plus.
You have turned me on to rechecking angle of the dangle.l
I know that welding teeth on is not the best way. Just thought I would try it, and see what happens. I did and I saw. :(
Pic shows a small pole that looked like it was "weaved" in between the teeth.
Thanks, Al
2025 80in. Hydraulic Dual Cylinder Root Grapple Skid Steer Attachment (A61567)
2025 80in...
Patterson water pump (A59230)
Patterson water...
LMC 12 Row Boom Sprayer (A60463)
LMC 12 Row Boom...
2025 Pabreak 74in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 74in...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
1990 Clements ES2S2836BT 28' Dump Trailer (A60462)
1990 Clements...
