Ram 2500 4x4 Cummins-opinions
   / Ram 2500 4x4 Cummins-opinions #171
The cummins is a great motor my 96,12 valve had 381k on it when I finally had to let it go. My current 05 has almost 100k on it just getting broken in. The 12 valve is still on the road a guy bought it redid it and sold it.
Getting close to oil and fuel filter services. Going with Rotella 5-40 synthetic. Any oil filter suggestions for this truck? Has a Mopar filter now. The dealer wants $300 to do the fuel filters. Seen a couple videos on changing them-not in the most convenient spots. I like to do my own maintenance and am handy with a wrench. Thoughts on doing this? Thanks in advance for all the help and guidance. This is my first Cummins, knowledge somewhat limited.
   / Ram 2500 4x4 Cummins-opinions #173
I have always used rotella 15w-40 I have changed my own filters and fluids very simple. Put a 5 gallon bucket under the oil pan and drain, the oil filter is pretty easy to get to an oil wrench can get it. Fuel filter is just a cartridge you change out once again not complicated. I have a K and N air filter my brother installed. I think they just need regular cleaning and then reoiled. Most everything can be found how to do through the cummins manual for that year truck, or check out youtube. I would not pay $300, I bet you fluids and filters cost about a third of that. Check out auto zone I have never specifically used just mopar filters just get the equivalent from the parts store. I have nothing against synthetic I just never have used it in my trucks. A over the road trucked used to by 15w-40 by the case for his riggs, and thats what he recommended.
   / Ram 2500 4x4 Cummins-opinions #174
What year is the truck again? The 13 and up 3500 or 14 and up 2500 have the newer frame and a cross member right in the way so the oil filter can be a little harder to remove.
I drop mine in a bag and pull it out from the side/wheel well. Some remove the air intake and pull from the top.
The fuel filters both have specific wrenches you can buy for a couple bucks, they both have plastic that can be damaged with ordinary tools.
You can find fleetguard filters on Amazon for cheap, I buy mine thru Genos garage.
Air filter (if it’s a 13 or up) shouldn’t be touched till you get a message on the dash. That’s what the Diesel Manual says anyway.
It’s easy to do and an owner should get familure with there rig whenever possible. DIY.
   / Ram 2500 4x4 Cummins-opinions #175
Go to genosgarage.com. Get the Fleetguard filters.
It is a 2018. First diesel I have owned in 10 years, first Cummins ever.
   / Ram 2500 4x4 Cummins-opinions #177
I’m using the T6 Rotella 5w-40 in my 2018 Ram 2500. Did one oil change but haven’t done fuel filters yet. No way in my mind should you need fuel filters every 7500miles. I’ll do them at next oil change.
Engine oil filter I used a Fram for synthetic oil. Might go NAPA gold next time, might not. It’s easiest to reach from the passenger front wheel well and on a lift. Turning wheels to left gave me enough room. Engine oil drains faster than the lift catch pans do. So have a bucket ready. DAMHIK.
One fuel filter on engine didn’t look too bad but a buddy has a 2018 3500 and said to be sure you change the oring. He didn’t at first and it leaked till he did. Other fuel filter is under bed. Directly above the drive shaft. That ones going to be fun. Easy to get to but I just see a diesel bath coming.
   / Ram 2500 4x4 Cummins-opinions #178
Definitely use the Mopar or Fleetguard (same thing) filters on your Cummins. Oil filters are the wrong place to cheap out and Fram filters have been proven to be the worst there is. Cummins even said not to use them as they can come apart if wet and clog the system. NO Fram. Do some research.
Second thing is no K and N air filters. These do not stop fine dust and cause more engine wear that the stock filters. There has been a lot of discussion about this over the years. Again, do some research. The stock filters flow plenty of air and work well. One cool trick is to put the 6.7 air filter in the 5.9 trucks as they fit but have more surface area. The Mopar filters are very good.
Maybe the best place to get filters is from Genos Garage. Slightly higher price, but they have everything.
You can also get a magnetic oil drain plug from Genos that is a nice addition to the Cummins.
Synthetic oil is better, but better enough to make it worthwhile? I don't know. I have always run Delo 400 in my three Cummins for about 500,000 miles. I always change the oil at 10,000 mile intervals, except for the first one at 5,000 miles during break-in. None of them have ever used a quart of oil between their oil changes in 10,000 miles! They are great engines. But, I refuse cheap out on filters. That would be ridiculous. Use what Cummins recommends.
If your engine begins to hunt at idle, add a bottle of Power Service when you re-fuel. This will clear it up for a number of tank fulls and only needs to be done occasionally.
At about 100,000 miles the AAM rear differentials begin to chatter. These are in every truck starting with model year 2003. The limited slip will begin to chatter as you start out with the front wheel turned, as in making a left turn from a light for instance, or while maneuvering a trailer. It's annoying, but won't hurt the truck. The fix is to change from the stock 85 weight oil to 140 weight oil. Full synthetic. This fixes it.
Fuel filters can be let go for much longer than the factory recommendation. The change interval is just an estimate and has little to do with reality. If you get a bad load of fuel, a brand new filter could be clogged in a mile or less, and if you never get a bad load, the filters could go 50,000 miles with no trouble. So, you never really know. I tend to change mine at about 50,000 miles and I have never seen one dirty, except for once when one clogged that had a lot less miles on it and I suspected a bad load of fuel. But it's good idea to manually drain the water separator once in a while just to check it. Especially in the winter.
It's also a good idea to put a cap in the "capless" fuel filler. What a terrible design that thing is! It invites water and dust to enter the tank. A simple 1 1/2" expandable plumbing plug from Home Depot does the trick. But they are not fuel proof. So you can order fuel resistant ones on-line or from a plumbing supply that will last a lifetime and are cheap., Or, you can look at Genos Garage for their aftermarket ones that are fancy and expensive. Either way, cap that filler! Even the stock shipping plastic plug is better than nothing.
Thanks for the tips. Big help!
   / Ram 2500 4x4 Cummins-opinions #180
^ This. If you do your research you'll see that the Fleetguard/Mopar filters are the best and what Cummins recommends. And another endorsement for Geno's Garage for anything Cummins. To save on shipping costs I buy a bulk pack of filters every few years.
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
Orico 3000 Cook Top (A51573)
Orico 3000 Cook...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
