RAM 3500 now 800lb.ft and 30,000lb GVWR!
   / RAM 3500 now 800lb.ft and 30,000lb GVWR! #141
Now look under my 2011 Ford F250 and you'll appreciate the difference, a real truck.
You don't have to get dirty climbing underneath them, see post :laughing:
Maybe that's the inspection plant where everyone can compare Ford's to Dodge's suspension!
http://www.tractorbynet.com/forums/...252-ram-3500-now-800lb-ft-12.html#post2265080
Sorry, just trying to be funny :)
I don't know, but when I bought my Ram 3500 it had the highest rated frame strength in it's class. Chassis truck, but I think it was even higher than Ford's 550s.
Something like 50,000 psi from what I remember from the sales brochures.
JB
   / RAM 3500 now 800lb.ft and 30,000lb GVWR! #142
Always wanted one in a Durango back in the late 90's when they made them that way.
Chris
Like this? A 1998 Durango in 1998 somewhere in Yellowstone. That Durango is the very first Durango delivered in Indiana with the 360. I ordered it with every single option available except rear air (because it cut out too much head room) and had to wait an extra month to get it with the 5.9 due to some delays. I'm glad I did. I kept it until 2009 and 200k miles. In that time the only problem it had was a problem in the rear end at about 150k miles. For many years it was my only tow vehicle for my boat (22' Sea Ray Pachanga) and any tractor I had. I miss it, but at 200k, there are just so many things that could start going wrong, it had served it's purpose for us.
   / RAM 3500 now 800lb.ft and 30,000lb GVWR! #143
....and the sticker price on one of there would be over 65K
   / RAM 3500 now 800lb.ft and 30,000lb GVWR! #144
Wait, are you referring to his durango being over 65k? I hope it was not that much!!! That would be a rip off to say the least.
   / RAM 3500 now 800lb.ft and 30,000lb GVWR! #145
Yesterday morning around 7:45 am I received a call from my nieghbor...
"Could you please come down by the school at the four corners and tow me home?"
I said, "sure thing buddy, I would love to tow a dodge with my GMC".
Best truck ever made, hands down.
Duramax, matched with the allison trans......enough said!
You sure about that? Had one and the only thing it was good at was finding its way to the dealer.
I am a Ford Guy but would own a Dodge 10 times over before another GM.
Chris
   / RAM 3500 now 800lb.ft and 30,000lb GVWR! #146
At one time I had a 04 F-250 4x4 Powerstroke and a 05 GMC 3500 SRW 4x4 Dmax at the same time. I pulled them side by side and spent a hour going back and forth on my creeper. No comparison. The Ford was just built so much tougher.
I then traded the Dmax and got a 06 F-350 SRW 4x4 Powerstroke and still had the 04 F-250. I did the same thing and while very similar the 06 with its new front suspension surpassed the 04. Both blew the Dmax out of the water with its Mickey Mouse torsion bar front end.
Chris
   / RAM 3500 now 800lb.ft and 30,000lb GVWR! #147
Chris
Give some examples if you can. It may help someone in their buying decision.
   / RAM 3500 now 800lb.ft and 30,000lb GVWR! #148
Frame thickness, mounting hardware, Ford solid axle versus a upper lower A arm assembly with torsion bars on the Dmax. Lack of boxed portions. ect.
Big issue for me was the low slung frame on the Dmax with the big cross member that went from frame rail to frame rail mid rig. I got it caught up on a stump.
Chris
   / RAM 3500 now 800lb.ft and 30,000lb GVWR! #149
Chris
Good points. I do admit, thought it rode rough, the solid axle in the ford felt and looked stronger than the GM.
   / RAM 3500 now 800lb.ft and 30,000lb GVWR! #150
Unless you know the characteristics of the steel being used in each vehicle looking at thickness don't count for much.:thumbsup:
All steels are not created equally.:D
(1) 300 Gallon of Double Concentrated Car Wash Soap (A51573)
(1) 300 Gallon of...
LMC G500-500A LOT NUMBER 232 (A53084)
LMC G500-500A LOT...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
Arksen Rollable Fuel Cell (A51573)
Arksen Rollable...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
LOT NUMBER 146 (A53084)
LOT NUMBER 146...
