Rayco 87L vs ASV 100 Forestry
   / Rayco 87L vs ASV 100 Forestry #31
the door safety switch shouldnt prevent the machine from starting...is the highflow switch on? or the lowflow? also check the quick attach switch if it is unlocked it will not start...the door safety switch will only prevent the machine from moving and the loader arms from moving (kills hydros) just to be sure you can trick the door switch by holding a anything metal up to the magnet on the right side (as you sit in the machine) of the cab facing where the door would go....hope this helps!
ps they should have just taped a wrench or something to the cab instead of bypassing switches...never a good plan! (you should see the rats nest of wires up inside the overhead console!)
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
Loader with IH Brackets (A50515)
Loader with IH...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
Genie GTH-644 (A50490)
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
TEST BID LOT (A50775)
