Re-bar Wrapped around axle
   / Re-bar Wrapped around axle #31
Hard to imagine a circular saw getting into the tines deep enough to reach a tightly wound rebar.
I agree with that observation. Wiggling a spinning angle grinder in amongst tines could be an exercise in getting hurt.
I would use a gas axe or a plasma cutter to remove it. Quick and painless.
I sometimes scratch my head at people's suggestions or if people have actually performed that particular operation or are just postulating....:laughing:
   / Re-bar Wrapped around axle #32
I wrapped an old rotting groundhog around a rototiller. The dog had buried it; I found it. Not physically hard to cut, except for the tears in my eyes and the occasional gag. :licking:
I'd rather deal with the rebar than the Woodchuck :laughing:
JB
   / Re-bar Wrapped around axle #33
JB
That's funny.
I believe I'd just set the depth control as deep as she'd go and 'till the carcass' into the soil. She might bump around a bit until decemated but at some point, the carcass would be.........dirt.:laughing:
   / Re-bar Wrapped around axle #36
I I sometimes scratch my head at people's suggestions or if people have actually performed that particular operation or are just postulating....:laughing:
I think most are suggesting something most households are likely to own. Not everyone owns gas cutting torches or plasma cutters.
   / Re-bar Wrapped around axle #37
If the OP doesn't have a grinder, it's a pretty safe bet that he doesn't have a torch or a plasma cutter. The recip saw will take maybe 10 minutes, the grinder maybe 5. Neither is particularly hazardous even for a novice, if you don't remove the safety shield from the grinder. Since the OP said he owns a recip saw, he probably has some experience with using it. Pay $3 for a good metal cutting blade and go at it.
He's probably finished already in the time it took me to type this.:laughing:
   / Re-bar Wrapped around axle #38
Since I found some good metal cutting discs for my small grinder my Sawzall only gets used for wood. I even bought a second grinder that stays set-up with a cutting disc...for those jobs that are too far away to reach with the plasma...
   / Re-bar Wrapped around axle #39
I have to say that I consider .045" cutoff wheels to be "consumables." That said, I often find uses for the recipro saw. Access is usually the issue.
   / Re-bar Wrapped around axle #40
Gimme the blue point tool anyday. Besides, you can't light your cigarette (after you are done) with an angle grinder or recip saw... or a Plasma. but you sure can with the Blue Point tool.......:D
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A56438)
2011 Ford F-550...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
