Ready to buy 4310
   / Ready to buy 4310
I turned in the credit app on 8/16 and the JD saleman didn't submit it untl 8/20 and called me this morning to arrange delivery. I told him to hang on that I was now looking at the Kubota L3130DT which I like as much as the JD 4310. I missed this model during my searches and was glad I found it before buying the JD. I still like JD but I can save over 2K and get more tractor. The dealer I'm buying from sells both JD and Kubota and said 6 years ago he would have bought the JD but Kubota has raised the bar and now recommends it over the JD.
   / Ready to buy 4310 #22
You're not getting more tractor. Compare HP. If you wanted an equivalent tractor you should have bought the 3430. Poof, there goes much or all of your savings.
   / Ready to buy 4310 #23
I didn't miss that L3130 whin I was shopping, and I still don't!
Not that its not a great tractor. When I bought mune the Deere was LESS than the Kubota. I would have still gone with mine if the Kub was less.
JMHO
   / Ready to buy 4310 #24
</font><font color="blue" class="small">( You're not getting more tractor. Compare HP. If you wanted an equivalent tractor you should have bought the 3430. Poof, there goes much or all of your savings. )</font>
JD 4410-35 gross HP
Kubota 3430-35 gross HP
JD 4310-32 gross HP
Kubota 3130-32 gross HP
I guess I'm missing something !
The 4310 and 3130 look like an even matchup to me.
   / Ready to buy 4310
4310 ePowrReverser:
* 32 HP Gross
* 27 HP PTO
* 2900 lbs
* 2200 lb 3PH lift capacity
* Ground Clearance: 10.5"
* 430 FEL: 1260 lb lift capacity at pivot pin
* Standard JD-specific Quik-Change for FEL bucket
L3130 DT:
* 32.1 HP Gross
* 25.5 HP PTO
* 3200 lbs
* 2650 lb 3PH lift capacity
* Ground Clearance: 14.2"
* LA513 FEL: 1345 lb lift capacity at pivot pin
* LA723 FEL: 1870 lb lift capacity at pivot pin
* Optional skid steer type quick attach for FEL bucket
* You can only run a MMM with R3 turf tires
Looks like More to me!
   / Ready to buy 4310
JD is nice but most of the tractor is made in Japan next door to the Kubota factory ( I heard they eat lunch together). I still like JD but they need to lower the price some. My savings total is approx. $2300 and operating these 2 tractors around the lot the Kubota feels larger and more stable. This is my first large tractor and I would be the owner of the JD if the salesman had been more attentive selling the tractor. Besides I'm thinking of painting the Kubota JD green when I get it.
   / Ready to buy 4310 #27
Gear model HP
JD 4410 PTO HP-29.5
Kubota 3430 PTO HP-28.5
JD 4310 PTO HP-27
Kubota 3130 PTO HP-25.5
I still don't see where the 4310 is a closer match to the 3430 than the 3130.
   / Ready to buy 4310
Ok, PTO HP...Everything else surpases the JD clearly. The PTO HP will be usefull for the cutter but that's it for me and 25.5 is more than enough.
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2017 Can-Am Side by Side (A51694)
2017 Can-Am Side...
2009 MORBARK 3800 WOOD HOG GRINDER (A53426)
2009 MORBARK 3800...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
2017 Hammerhead Off-Road Utility Cart (A51691)
2017 Hammerhead...
