Copperhead
Veteran Member
Semi truck fuel economy has not gone up that much has it? I have a friend who hauls over length power poles and has a few trucks. His '91 Freightliner with a Detroit diesel gets 11 MPG loaded. His 2007 Freightliner with Detroit diesel gets 4 MPG. Our 1971 6x6 "Duece and a Half" with a white turbo diesel gets 10 MPG.
The lifetime average mpg on mine hovers right around 8 mpg. I have a 2013 semi truck, but I have a 2000 year build Detroit in it. I haul light and heavy with a 53' dry box trailer. Lots of bulk feed and bulk dried eggs, oatmeal, granola, etc. My average gross is right around the 65,000 lb that was mentioned. The heavy stuff, of course, gets close to 80,000 lb GCVW.
There are some operators that are doing will into 9 mpg territory with their semi trucks, and I know one that has a documented run from California to N. Carolina, grossing 72,000 lb, and busted 10 mpg average for the entire run. That is with a 2015 Freightliner Cascadia with a DD15 motor. That run was documented and confirmed by Freightliner.
Just based on those examples, it is not unreasonable to expect a 6.6L Dmax with a 5th wheel camper, that total would not exceed GCVR, to get a minimum of double the mpg at gross weight, or even more, than these semi trucks. After all, the semi motors are 2.5 times larger, the gross weight is 3-4 times as much. And when we factor in the total dimensions as well, the semi is displacing and fighting a lot more air and wind. And then there is the actual number of tires and the footprint they are placing on the ground, which has an effect on mpg as well. So I still contend, the pickup OEM's have really dropped the ball on what they could be getting for mpg in a 6.6L Dmax, or any other brand of pickup diesel in a 3/4 or 1 ton. They should be getting 20 mpg for an average while towing.
