Realistically, how many hours can I get out of a BX1500?
   / Realistically, how many hours can I get out of a BX1500? #11
[/QUOTE]
My kubota manual says to replace the outside air filter yearly or every six times of cleaning it. I would agree with your mechanic if you have a single filter system. the 'bota has an inner and outer filter. Only the outer is cleaned.[/QUOTE]
My L2800 only has one filter, the inner filter is listed as optional, I plan to buy the inner filter next trip to the dealer. I would replace the outer filter once a year, and yes dirty air filters provide better filtration than clean, but with no differential pressure indication, they can fail and can dump all that dirt into your engine.
   / Realistically, how many hours can I get out of a BX1500? #12
Dirty air filters in an engine means a hindered air flow that is restrictive so where do you get the air from when it gets to dirty? I don't even want to go there!!!!!!! There are mechanics out there that might be able to fix something, and there are technicians that do! I never in all my days and years have heard of running a dirty air filter. Sorry boys!
   / Realistically, how many hours can I get out of a BX1500? #13
I had 2 old B1700's?, (I think that was the model number). That came in from the local railroad. These had about a 20hp 3-cylinder Kubota. One machine had 9000 hours, the other 12,000.
This might be stretching it alittle, but it's something for you to shoot for!
Good luck,
DDL
   / Realistically, how many hours can I get out of a BX1500? #14
Bottom line: with regular maintenance there is absolutely no reason that your machine shouldn't last a lifetime with nothing more than minor repairs here and there.
We've all heard stories about old machines and rediculous numbers of hours. I have a family member with a 22 year old L-series, stored outside, unprotected from the elements in the southtowns of Buffalo, NY (they get 140+ inches of snow per year) and the machine is not particularly well maintained. Nevertheless, it still starts up and runs great every time. As a matter of fact, it's probably out there on snow removal duty as I write this.
The sum total of problems? The fuel tank rusted out last year and had to be replaced. That's it. If anything, you might have to worry about never being able to wear the darn thing out!
   / Realistically, how many hours can I get out of a BX1500? #15
My cub cadet has a commercial Vanguard gas engine. These are rated for 2000+ hours and often go up to 3000 with no major problems from what my dealer says as long as proper maintenance is done. Mine is a 94 and is only turning 700 hours now!!!
Properly maintained diesels should run at least twice as much as that so 5000 to 6000 hours should be typical and even then it may need minor work and not a full tear down.
Lets face it, for casual home owner use like most of us (50-100 hours a year) these things will be handed to our kids in our wills!!!!
   / Realistically, how many hours can I get out of a BX1500? #16
Looks like you have about 60 more years of use.
   / Realistically, how many hours can I get out of a BX1500? #17
The 1500 has a nice looking little motor in it. Seems like it would be worth freshening up when the time comes. I wonder what kind of rebuild parts are available for them?
   / Realistically, how many hours can I get out of a BX1500? #18
I work in the air pollution field and service baghouses used for ventilation cleaning and for flue gases cleaning from coal combustion. Have done this for 35 yrs. now.
That said, it is well known and universally accepted by all in the industry (both users and manufacturers) that a new filter will allow higher than desired particulate (dust) to pass through the filter until a "dust cake" is established. The filter media forms the substrate for the dust cake that actually provides the filtration! While a virgin/new filter provides a certain level of filtration, that level is much lower than a properly conditioned/dirty filter.
New filters are routinely precoated with dust before being placed into service so that the maximum collecting efficiency is achieved from the start! Most filters are allowed to have a pressure drop of 6" water column and then are cleaned down to 3" or so. Over aggressive cleaning is very undesireable as the beneficial dust cake is removed and the filter media may be damaged.
The filter pressure drop (how dirty is it) can easily be measured with a U tube manometer. A very accurate "U" tube manometer can simply be made with clear plastic tubing filled with water in the shape of a U. The difference between the height of the two levels in the tube indicate the pressure drop. One end of the tube needs to be connected after the filter and the other is open to the atmosphere. A simple 1/4" tapered plastic connector could be screwed into the ducting after the air filter to connect the tubing.
This type of device, a manometer, is commonly used by motor tech's to balance multiple carburetors on engines. There are no moving parts or springs that can give erroneous readings.
A new "clean" filter does not work better at removing dirt than a filter that has been in service for a while. This may go against what we all have been led to believe, but these are the facts that are known and accepted by everyone in the filtration business. A filter is just fine and will continue to filter dust well until the pressure drop reaches that point that the air flow reduction results in an overtly rich fuel condition. Until then, a "dirty" filter works better than a "new/clean" filter.
   / Realistically, how many hours can I get out of a BX1500? #19
bxowner said:
I've seen some listed for sale with 300 hours for not a whole lot less than I paid for it...
I figure I'll put ~40-50 hours per year.
At that rate, figuring I maintain it and don't abuse it, can I get 10 years out of it? 20?
I have 2 Bolens Garden Tractors
40 and 41 years old and still going good.
They only cost about 800 to 1000 bucks new back then.
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
2019 KUBOTA SVL75-2 SKID STEER (A52705)
2019 KUBOTA...
Doosan 7' Bucket (A50775)
Doosan 7' Bucket...
YAMAHA IPOWER SC2400IP INVERTOR GENERATOR (A54756)
YAMAHA IPOWER...
2005 Kenworth W900 T/A Sleeper Cab Truck Tractor (A55788)
2005 Kenworth W900...
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A54757)
UNUSED RAYTREE...
