Rear blade advice
   / Rear blade advice #11
The angle is a pin in the back. That turnbuckle is for the offset which is definitely not the quickest adjustment. But I already located one of those adjustable links with the pin and multiple holes to swap it out for. May be a moot point though because at this point I’m leaning towards turning it down and just buying a cheap light duty blade. All I really need it for is light snow on a paved driveway (when it’s not deep enough for the blower) and some light grading in the yard.
For that use, I would definitely get a smaller blade.
   / Rear blade advice #12
The angle is a pin in the back. That turnbuckle is for the offset which is definitely not the quickest adjustment. But I already located one of those adjustable links with the pin and multiple holes to swap it out for. May be a moot point though because at this point I知 leaning towards turning it down and just buying a cheap light duty blade. All I really need it for is light snow on a paved driveway (when it痴 not deep enough for the blower) and some light grading in the yard.
Sorry, I see now that you explained it.
Good luck on your new choice for a rear blade.
KC
   / Rear blade advice
OK, we pulled the blade out of the deal. Now I'm on the hunt for decent rear blade mostly for snow. I'd love to find one with an offset feature. Any recommendations?
   / Rear blade advice #14
Why do you think you want an offset?
   / Rear blade advice
Even though my driveway is paved, it's lined with golf ball size landscape rocks on all sides. Inevitably, they end up getting sucked into the blower when I get too close. My driveway is narrow enough so I can't just stay 6-12 inches clear of the edge. The offset will allow me to run the blower that 6-12 inches away while pushing the remaining 6-12 inches off into the rocks. So I suppose I don't NEED it as I could just drive off the driveway by a foot or two with the blower up and blade down but it would make it much easier and make less of a mess.
   / Rear blade advice #16
I think you will find that a 5 or 6 foot blade will be enough wider then tour tractor that it will do what you want it to without an offset.
And MUCH cheaper.
   / Rear blade advice #17
I would absolutely recommend turning that particular blade idea down!
I would also suggest not buying just any old cheap blade.
You should call Everything Attachments for blade advice.
They make a blade that is far superior, and MUCH simpler to adjust, than that Tuffline blade in your picture.
They charge $913 for their 5 foot 6 way deluxe blade, with "free shipping".
It is worth every penny!
   / Rear blade advice #18
Look how easy it is to offset this rear blade (at 4:27)
   / Rear blade advice #19
This blade is similar to the EA 6 Way Deluxe Scrape Blade,.... but NOT AS NICE as the EA blade!
2005 Ford F-650 2,000 Gallon Water Truck (A53422)
2005 Ford F-650...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A55852)
2015 Ram 5500...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
