rear blade/want hydraulics to turn
   / rear blade/want hydraulics to turn #1
12pack
Westchester County, N.Y.
Kubota BX-22 / Mitsubishi-372
I tried search
I have a Kubota BX-22.
I want to install a hydraulic piston to move the rear blade left and right while plowing snow.
Any pics or tips on this install?
   / rear blade/want hydraulics to turn #3
we offer fully customized hydraulic sidelink and a hose kit and your color paint with free shipping for the month of december
Just ask for Travis
   / rear blade/want hydraulics to turn #4
I tried search
My advice is to get a minimum of a 3" dia cylinder. You will not find ANY OEM manufacturer of rear blades that uses anything smaller to angle the blade, most use 3 1/2" or 4". I also would recommend a minimum of a 12" stroke, again the OEM guys use 14" and 16" stroke cylinders, but those are on larger blades. A lot of guys end up using smaller units and while they do work, they should have used a bigger hydraulic unit in my opinion. Take a look at these drawings to get a good idea of how the OEM units are done.
Good luck and please be sure to show us pics. :cool:
   / rear blade/want hydraulics to turn #5
Think about this, the end user has a BX-22 and you say a 4" cylinder on a blade.
When you look at the drawing link, LandPride RBT35 uses a 2" cylinder for both tilt and side movement. The 3.5" cylinder is only for an optional guage wheel and it has a 1600 psi cushion valve on it. This RBT-35 blade is way too big for a BX-22.
   / rear blade/want hydraulics to turn #6
I did not suggest a 4" cylinder. :confused: I said that a 3" cylinder should be the minimum dia and the RBT35 uses a 2x6 cylinder for tilt, a 3 1/2" x 14" for angle and offset. I have NO idea where you have come up with the figures that you have listed? :confused2: As far as showing the RBT35 drawings, that was to give the guy an idea of how the OEM guys set their blades up, not recommending that blade for a BX, he already has a blade. Come on now, do you really think that I am that far out there? :confused3:
   / rear blade/want hydraulics to turn #7
I agree with MtnView, 3" minimum cylinder.
While it will only take the force of a very SMALL cylinder to angle the blade, it is holding it angled that becomes the issue. Especially if you catch a curb or something with the edge. Or if you are also planning on using it for dirt work in the summer.
The edge of the blade becomes a very long lever trying to move the cylinder. It can create extreme pressure and unless you incorporate a relief into the system if you use a small cylinder, it isnt too hard to overpressurize and pop hoses.
   / rear blade/want hydraulics to turn #8
12-pack,
I've linked to the three threads that were created when I added a cylinder to my rear blade.
One is adding a remote valve, another is adding a cylinder, and the third is re-designing after a few problems. It's a fair bit of reading, but it may save you some issues and extra expense. Mine works very well now, no problems since the re-design.
If you have any specific questions, feel free to ask.
http://www.tractorbynet.com/forums/hydraulics/188519-adding-rear-remote-kubota-l3400.html
http://www.tractorbynet.com/forums/welding/189597-adding-cylinder-mount-rear-blade.html
http://www.tractorbynet.com/forums/hydraulics/192127-cylinder-travel-limiter.html
Sean
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A53843)
2018 KENWORTH T800...
RIGID TOOLBOX (A52472)
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
